Does Mid Grade Gas effect performance? - Mercedes-Benz Forum
post #1 of 17 (permalink) Old 01-26-2012, 03:43 PM Thread Starter
Date registered: Jan 2012
I just purchased a 1989 260e. The owner before me said he would put mid grade gasoline in the vehicle. The owner (an older man) stated that he would just take the car on short trips and not out that often. The car is 24 years old and has 89,000 miles. I put mid grade in and feel a hesitation/lag when first starting the car and driving for the first 5-10 minutes, then once the car is warm it drives fine. Would premium gas make the vehicle run better with more pep?
Joey Cataldo is offline
post #2 of 17 (permalink) Old 01-27-2012, 09:28 AM
Musikmann's Avatar
Quoted: 6 Post(s)
Is there any octane requirement listed in the owner's manual or on the filler cap? I would try the higher octane gas to see if it helps. Or better yet, that's a W124 so find that forum in the sedans section and do a search for "octane" or "fuel".
Musikmann is offline
post #3 of 17 (permalink) Old 01-27-2012, 10:39 AM
Kajtek1's Avatar
Quoted: 1169 Post(s)
Lower grade gas should not have affect on starting the car. The difference will show under heavy load, when the engine start pinging.
Don't do it. If the car is design for Premium -put Premium in it. You want to run car on cheaper grade -buy a Prius.
Kajtek1 is online now
post #4 of 17 (permalink) Old 01-27-2012, 01:56 PM
Date registered: Jun 2009
Vehicle: 1991 300E
I have found that middle octane gas, 89, gives me better mileage than premium and equal performance in my 1991 300E.
300E91 is offline
post #5 of 17 (permalink) Old 01-27-2012, 06:10 PM
Kajtek1's Avatar
Unfortunately that is not technically possible.
With lower octane the engine performs less, what might end in fuel savings, but those things that give you more HP and better gas mileage at the same time don't really exist.
post #6 of 17 (permalink) Old 01-27-2012, 06:15 PM
PLeeson's Avatar
Date registered: Apr 2007
Quoted: 5 Post(s)
To the OP's issue, a quarter-of a-century-old car with only 89K miles might do well to have a little run at high rpm with a double dose of seafoam or techron.
His problem might be sticky injectors.
Also agree that 91 octane is best
Phil
Prior MBs:
1971 250, 1983 380SEL
1986 190E2.3, 1987 300TD
1994, 2003, 2005 SL500s
2001 E320 4Matic
2011, 2012 E350 4Matics
2012 S550 4Matic
PLeeson is offline
post #7 of 17 (permalink) Old 01-27-2012, 06:19 PM
Musikmann's Avatar
Quoted: 6 Post(s)
I don't understand that either. But if the 260E and 300E are based on the same platform the results of 89 mid-grade might be the same for both. Personally I will run what the MB engineers say to run in my car and that is 91 octane.
post #8 of 17 (permalink) Old 01-27-2012, 06:23 PM
PLeeson's Avatar
Quoted: 5 Post(s)
For me, anyway, I'm pretty sure those MB Engineers know more than I do!
Same deal for K&N filters, "performance" chips, etc...
Phil
Prior MBs:
2001 E320 4Matic
2012 S550 4Matic
PLeeson is offline
post #9 of 17 (permalink) Old 01-28-2012, 09:04 AM
Vehicle: 1991 300E
Gasoline Octane rating tells how much it can be compressed before it spontaneously ignites. Interestingly, a higher octane fuel has a lower energy content than a lower octane rated fuel. The lower power content of high octane fuels can be overcome with higher compression engines, which results in a higher expansion ratio and thus a higher work output. If the engine is not high compression, it will never realize the benefit of high octane gasoline. The M103 engine in my 300E has a compression ratio of 9.2:1; it is not a high compression engine. I assume that the OP's 260E is similar.
I've done comparison tests of high and mid octane gas for more than a year. I typically fill at the same station, drive largely the same routes and always logged my data in a spreadsheet. Fuel mileage and cost per mile are clearly better with mid-grade gas. This is not anecdotal evidence.
See one of my earlier postings which cites a variety of experts and sources on this subject: post4108568.
300E91 is offline
post #10 of 17 (permalink) Old 01-28-2012, 09:33 AM
Kajtek1's Avatar
Its been very long time since I drove car on regular, but I remember filling our Volvo with Premium for mountain driving. This way the engine would take several hills on overdrive, while on regular it would have to downshift. My action was not focused on fuel saving, but on time saving -I was getting to the destination faster and that was my priority. That was in the times when Premium cost 25% more than regular.
Than even technically regular has minimally more energy, the higher compression engines do have much better efficiency. Not having lab test we can only speculate how much one offsets the other.
Bottom line -on regular or mid you have to drive slower and that where the savings are coming from.
    Does a vaccuum leak effect engine performance? GRAND MASTER B W126 S,SE,SEC,SEL,SD,SDL Class 1 08-20-2008 07:25 PM
    Grade 5 vs. Grade 8 Bolts...Which one to get? saigonsmuggler G-Class 14 03-06-2006 08:17 PM
    what gear oil is best for the differential? grade 90 or grade 140 drebdy W123 E,CE,D,CD,TD,TE Class 2 02-16-2005 06:44 PM
    Grade and types of gas Vs. performance soman11 W203 C-Class 13 08-30-2004 11:04 AM
    Does chrome make the wheel heavier, and if so, will the heavier wheels effect performance? Todd - Philadelphia R170 SLK-Class 3 02-28-2001 08:59 AM
