Does Mid Grade Gas effect performance? - Page 2 - Mercedes-Benz Forum
post #11 of 17 (permalink) Old 01-28-2012, 09:37 AM
Kajtek1's Avatar
Quoted: 1195 Post(s)
Just as a sample how much efficiency high compression brings.
Gasoline engines with compression 8-11 have 30-35% of efficiency.
Diesels with compression >20 are having 40-51%
Kajtek1 is offline
post #12 of 17 (permalink) Old 01-28-2012, 10:36 AM
Date registered: Jun 2009
Vehicle: 1991 300E
Originally Posted by Kajtek1 View Post
Bottom line -on regular or mid you have to drive slower and that where the savings are coming from.
That is simply not true.
300E91 is offline
post #13 of 17 (permalink) Old 01-28-2012, 10:52 AM
Kajtek1's Avatar
PROVE IT?
Kajtek1 is offline
post #14 of 17 (permalink) Old 01-28-2012, 11:07 AM
Musikmann's Avatar
Quoted: 6 Post(s)
300E91,
I just read your post and that is pretty convincing. Not only all of your cited experts, but the 60 tank study you did yourself.
Although I choose to use premium fuel I have stated several times, ignoring octane rating for the moment, that it's best to stick with top tier fuels. The last time I checked the list, the only one here is Shell. I used to use Chevron/Texaco but they pulled out and Shell came in so that's why I made the change.
But as an aside, I continue to add Techron every 3000 miles as a preventative.
Musikmann is offline
post #15 of 17 (permalink) Old 01-28-2012, 11:25 AM
Vehicle: 1991 300E
Musikmann,
Thanks for taking the time to read my earlier posting. I believe decisions should be made on accurate information, not anecdote and mythology.
Your decision to use "top tier" suppliers is completely consistent with the advice of the experts I cited. Since there are only a few refineries, the same fuel goes to many different outlets. Some stations may end up contaminating the fuel with leaky or poor condition tanks and such. Off-brand stations often look suspect in that regard to my eye while refinery-owned and franchised stations are more likely to have higher quality control. Like you, I'm a fan of Techron also.
300E91 is offline
post #16 of 17 (permalink) Old 01-28-2012, 11:40 AM
Musikmann's Avatar
Quoted: 6 Post(s)
Top tier
300E91,
You're welcome, very worth the time spent. BTW I just noticed Exxon finally made the grade (no Mobils here) so now at least I have a local alternative.
post #17 of 17 (permalink) Old 01-28-2012, 12:05 PM
Date registered: Dec 2009
Vehicle: 1997 E300D
Quoted: 20 Post(s)
[QUOTE= Interestingly, a higher octane fuel has a lower energy content than a lower octane rated fuel. [/QUOTE]
Actually, higher octane fuel has a GREATER energy content because it uses larger molecules on average than does lower octane gas. As a result, it burns more slowly than regular gas. In high compression engines, regular gas can light off too soon, before the spark, causing pinging.
nelbur is offline
    Does a vaccuum leak effect engine performance? GRAND MASTER B W126 S,SE,SEC,SEL,SD,SDL Class 1 08-20-2008 07:25 PM
    Grade 5 vs. Grade 8 Bolts...Which one to get? saigonsmuggler G-Class 14 03-06-2006 08:17 PM
    what gear oil is best for the differential? grade 90 or grade 140 drebdy W123 E,CE,D,CD,TD,TE Class 2 02-16-2005 06:44 PM
    Grade and types of gas Vs. performance soman11 W203 C-Class 13 08-30-2004 11:04 AM
    Does chrome make the wheel heavier, and if so, will the heavier wheels effect performance? Todd - Philadelphia R170 SLK-Class 3 02-28-2001 08:59 AM
