2002 S430 No crank - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 01-25-2012, 05:32 AM Thread Starter
Date registered: Jan 2012
Talking 2002 S430 No crank
Hi to all, This is my first round on this forum. I have a 2002 S430. All was great until the connector on the 722.6 trans starting leaking. I pulled the car in the garage and all was fine. 2 days later I replaced the connector housing with new o-rings on the trans. Added 1/2 quart trans fluid, went to start car to check my work and the engine wont crank. The dash lights, shifter, fuel pump all come on, just will not crank. If you turn the key real fast to the start position it will engage the starter for a split second every other time. I'm wondering if I disturbed something at the wiring harness at the connector when I replaced the housing. Maybe the trans lock out wire broke ??? How dependent is the trans fuid level on the no start contact in the trans . Does it have to be within a certain range / level to allow the engine to start
Thanks for any help with this. Ken.
redrumtwo is offline
post #2 of 2 (permalink) Old 01-25-2012, 06:36 AM Thread Starter
Ok, I did some more research and found out that if the center bolt on the connector is over tightened ( spins ) that the conductor plate is now bad, I would assume this would cause a no crank situation ! It did spin due to over tightening the bolt... Ooops..
Does this sound correct? Thanks, Ken.
    2000 S430 wont start or crank!!! streetfighterz05 W220 S-Class 171 09-04-2013 01:21 AM
    2001 S430 won't crank/start chp10_8 W220 S-Class 2 12-23-2010 10:05 PM
    S430 will not crank or leave P S430TX W220 S-Class 4 12-10-2010 10:13 AM
    <<< AMS S430 / S500 Performance Crank Pulley >>> AMSports W220 S-Class 0 08-12-2008 10:41 AM
    2000 S430 won't crank basznijo W220 S-Class 0 05-20-2007 03:58 PM
