Piston rings, W201 etc inc, Cosworth - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 01-25-2012, 03:29 AM Thread Starter
Black eagle's Avatar
Date registered: Jul 2006
Vehicle: 2001 A170 CDi. '87 BMW 320i. '95 Eagle SS Kit car, '99 Suzuki AN400X
Smile Piston rings, W201 etc inc, Cosworth
Having to replace my piston rings in the 1987 23.3-16v Cosworth I found it very hard to find the correct specification rings at a sensible price, until that is I came across Bradford Grindings Ltd. A set of four cost only £95 inc tax plus postage, They prefer to use DHL but if you insist will send by normal post at your own risk as I did using Royal Mail airmail with no problems. They may need you to remove a piston and check the thicknesses as there are a couple of variations apparently.
Mine had Mahle Pistons and Goetz rings. which is the make they supplied.
Make & model.........year..Cylinders...Bore......1....... 2......3
190 E 2.3-16 Valve..1983>.....4.......95.50...1.50...1.75..3.50
Set number 2234 M102-983---3.760-1-K-1-SK-1-O
Black eagle is offline
    Piston Rings vanish V-Class 3 07-14-2011 12:08 PM
    new piston rings Funkaduck W124 E,CE,D,TD Class 4 12-18-2010 09:43 PM
    Piston rings M100 6.9 supercharger6.9 R/C107 SL/SLC Class 2 10-18-2009 05:05 PM
    Piston Rings, when do I know? princejimi W124 E,CE,D,TD Class 9 05-06-2006 12:14 PM
    piston rings tmn G-Class 10 07-27-2001 05:21 PM
