Intermittent Climate Control/Air Conditioning - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 01-23-2012, 02:46 AM Thread Starter
Date registered: Mar 2010
Hi there,
I have a 1999 E320 (petrol) estate/station wagon which has been displaying unusual behaviours from the climate control.....
The fans seem to have a life of their own and their speed/performance bears no relation to the digital fan readout in the climate control unit. An example would be when you need maximum defrost.....the climate control head unit shows the fan speed at full (i.e. all bars) yet, little or no air is emitted from the vents. You will be driving along and then suddenly, the fans burst into life for a minute or so and then shut down or slow down whilst the display shows full power. The same behaviour happens whether you want cold or hot air. The other behaviour is like a pulsing where they will speed up and slow down regularly.
All of these behaviours are completely independent of the what the control unit says.
I have had the a/c recharged and bought a new climate control head unit (from Ebay) - neither of which has solved the problem.
It was suggested to me that the fan resistor pack/unit has failed but wanted to check with this forum first in order to gain advice (and before I buy yet another unnecessary unit )
red_baron is offline
post #2 of 2 (permalink) Old 01-23-2012, 08:33 AM
Musikmann's Avatar
Quoted: 6 Post(s)
It might be the blower motor regulator, a common problem. Come join us on the W210 forum (found under the sedans heading) and search for "regulator". Several threads should come up. I think the fan resistor pack/unit is the same thing. Good luck and welcome to BW.
Musikmann is offline
climate control intermittent dpiswing@aol.com R129 SL-Class 6 07-27-2011 08:55 AM
Climate control intermittent wrooper W124 E,CE,D,TD Class 3 10-05-2009 01:50 PM
E300 Climate Control/Air Conditioning WooDooUK W124 E,CE,D,TD Class 1 11-24-2008 09:07 AM
climate control a/c air conditioning 134a hyoung888888 W126 S,SE,SEC,SEL,SD,SDL Class 5 09-05-2008 01:13 PM
climate control fan intermittent peyton300td W124 E,CE,D,TD Class 4 08-14-2008 02:43 AM
