Vito oil leak - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 01-22-2012, 05:02 PM Thread Starter
Date registered: Jan 2012
Vehicle: vito 2.2 cdi 110 bhp 8 seater
Vito oil leak
Seems to be beside timing chain would it be crank shaft oil seal
DRI94VER is offline
post #2 of 2 (permalink) Old 01-22-2012, 06:07 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Probably best to post in the Vito forum...
On the petrol engines there is a little diamond-shaped cover ruth a threaded plug on the front of the timing case that is prone to leaks, so that is something to check.
Good luck.
Check Codes is offline
    Vito oil leak DRI94VER BenzWorld Help 1 01-28-2012 06:07 AM
    Vito 108cdi fluid leak Don-vito V-Class 1 09-24-2010 05:49 AM
    Vito 108D Coolant Leak gavinrobertson42 V-Class 7 01-07-2010 05:00 PM
    Exhaust leak on vito 122... pranda V-Class 2 11-15-2007 11:59 AM
    Vito 111 CDi Water leak - Urgent! Chris111 V-Class 1 01-16-2006 04:23 PM
