Need some help with my benz ML320 - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 01-22-2012, 04:17 PM Thread Starter
Date registered: Jan 2012
Vehicle: 1998 Mercedes Benz Truck ML320
Post Need some help with my benz ML320
I bought a 1998 Mercedes Benz ML320 I have a code that came up the other day it was P0700 Transmission Control System Malfunction.
I have read alot of forums that state that changing the conductor plate will fix it.
Heres what my truck is doing,The fluid was low I filled it to MB specs.
It drives fine for awhile until it gets up to temperature, then if I turn the truck off, then when i restart it it goes into limp mode. As long as I dont turn it off she drives and shifts great.
What could it be, i will have to do the work myself as I cannot afford to take it to the dealer.
Any help is much appreciated. Thank you in advance
BIGAZDAWG is offline
post #2 of 2 (permalink) Old 01-23-2012, 01:44 PM
Musikmann's Avatar
Quoted: 6 Post(s)
You'll be much better off asking this on the W163 forum as there are several great diagnosticians and lots of owners there. But your garden variety scanner only gives you very generic MB transmission codes so you need to get a better scan before throwing parts at the truck.
And you need to discover why the ATF was low. There is an electrical connector that is prone to leak and fluid can wick up the wires into the transmission control module. That might also explain your symptoms.
Musikmann is offline
    New and first Benz W163 98 ML320 slim79 General Mercedes-Benz 0 05-08-2010 04:44 PM
    ML320 BlueTEC on Mercedes-Benz TV Wolfgang W164 M-Class 1 09-28-2008 12:17 PM
    Security Code for Mercedes-Benz ML320 mithra General Mercedes-Benz 2 06-03-2004 01:44 PM
    Security Code for Mercedes-Benz ML320 mithra W163 M-Class 3 06-03-2004 12:00 PM
    Mercedes-Benz ML320 Haris W163 M-Class 1 01-17-2003 10:39 AM
