cheap high octane gas! - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 01-22-2012, 09:06 AM Thread Starter
Date registered: Nov 2006
Vehicle: 70 406
take regular gas and add some diesel. Octane boosters say to add 16oz. to 25 gallons of fuel, (or 473ml (half Litre) to 95Liter). basically .5L to 100L to raise fuel 2-3 points. add 1L to 100L to make 94 octane fuel. 32 Oz to 25 galloons of regular to make 25 gallons of 94 octane
Diesel and Kerosene is very similar, will work if mixed up.
Kero is #1 fuel oil, diesel fuel is #2
Difference is the parafin/ wax content or long chain hydrocarbon molecules 10-18 molecules per chain for thicker oil products.
kero has less heat per gallon than #2 diesel, kerosene burns much cleaner with less BTU per gallon,
Kerosene and jet fuel are the same thing just filtered better.
Kero is added to diesel in the winter to lower the cloud point or the temp that the parafin in the diesel starts to solidify.
Check SECTION 3 of the Material Safety Data SHeet. Octane booster is 60-100% Kerosene. Other ingredients make up 1-5% at the most. 100% Kerosene!!!
http://www.amsoil.com/msds/aob_cob.pdf
Pass it on!!!
bandit86 is offline
post #2 of 12 (permalink) Old 01-22-2012, 12:24 PM
DEVOURS's Avatar
Date registered: Dec 2006
Vehicle: 2006 B 200 .....& Audi A6..
Quoted: 101 Post(s)
One of the best kept secrets........
.....but what are the down sides ..if any..?
DEVOURS is offline
post #3 of 12 (permalink) Old 01-23-2012, 03:58 PM Thread Starter
Vehicle: 70 406
I've been running regular instead of premium in my land rover for years with no problem. how bad could octane boosters be? Kerosene is 99% of it. I'm curently overdosing the rover, added 2 gallons to a full tank. runs alright so far. will pull the plugs in a few fillups
bandit86 is offline
post #4 of 12 (permalink) Old 01-25-2012, 03:34 AM
Black eagle's Avatar
Date registered: Jul 2006
Vehicle: 2001 A170 CDi. '87 BMW 320i. '95 Eagle SS Kit car, '99 Suzuki AN400X
Downsides? In MOST countries it is illegal to use Kerosen (parafine etc) as a fuel or part of.
In most countries you can't buy less than 95 anyway.
Black eagle is offline
post #5 of 12 (permalink) Old 01-25-2012, 09:45 AM
Date registered: Aug 2011
Quoted: 8 Post(s)
Interesting, but isn't diesel lower octane than gasoline? Just wondering how adding something that is lower octane will increase the octane rating of the final mixture.
Taurine is offline
post #6 of 12 (permalink) Old 01-25-2012, 09:49 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Aside from increasing carbon in the combustion chambers and damaging your cats and O2 sensors, I can't imagine any downside to blending diesel with gasoline...
Check Codes is offline
post #7 of 12 (permalink) Old 01-25-2012, 11:51 AM
SaleenS7's Avatar
Date registered: Apr 2005
Quoted: 2 Post(s)
Exactly. Kerosene would be too harsh for the injectors and manifold as well. The extra carbon deposits would have to be cleaned from the pistons, the intake manifold, combustion chamers and other parts over time.
If your car 'requires' premium then stick with it. If it 'recommends' premium then you can get away with regular at the expense of less power.
SaleenS7 is offline
post #8 of 12 (permalink) Old 01-25-2012, 12:05 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
Ethanol enhances octane.
"Octane" BTW is nothing but a measure of a fuel's resistance to preignition.
It doesn't create more power, it just allows the engine to be tuned to make more power, i.e. have higher compression.
It's pretty much wishful thinking to think there are significant secrets like this out there.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #9 of 12 (permalink) Old 01-25-2012, 03:21 PM
MTI
MTI's Avatar
Vehicle: '85 2.3-16 '99 C280 '11 GLK350
Not to mention cheapskate Mercedes Benz owners.
MTI is offline
post #10 of 12 (permalink) Old 01-26-2012, 01:31 PM
DEVOURS's Avatar
Quoted: 101 Post(s)
I was hoping that Greg would come to the rescue here and tell it like it is. ..
BTW...your 95 is not our 95 ...you have to be a little more specific when quoting octane #'s here.
DEVOURS is offline
High Octane Gas TarheelMBS W164 M-Class 22 02-25-2011 05:17 PM
High Octane ferrymanau W124 E,CE,D,TD Class 5 06-21-2007 02:53 PM
Toulene High Octane Race Gas omeyhomey W210 E50 AMG, E55 AMG 2 01-22-2007 09:55 PM
HIGH OCTANE BOOSTER Chucky300 W220 S-Class 3 04-13-2005 08:59 AM
high octane gas AMG! W211 E55 AMG, E63 AMG 3 12-09-2004 11:47 AM
