Tire Pressure - B180 - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 01-19-2012, 12:48 PM Thread Starter
Date registered: Oct 2010
Good Day Guys
I got a B180, 2009 model and recently I got four tires relpaced with "Dunlop" tires.
My car indicates that tire pressure must be 29-30psi.
The tire company says it must be 36psi.
Which one should I follow?
Also, please let me know the difference between wheel balancing and allignment.
If difference, should I get both done when it is due for next wheel allignment.
Thanks in advance.
NcgOsh is offline
post #2 of 4 (permalink) Old 01-19-2012, 01:29 PM
DEVOURS's Avatar
Date registered: Dec 2006
Vehicle: 2006 B 200 .....& Audi A6..
Quoted: 93 Post(s)
How did the tire company tell you that it "must be" set at 36 psi..? Is it because that is what's marked on the tire sidewall?
DEVOURS is offline
post #3 of 4 (permalink) Old 01-19-2012, 03:08 PM Thread Starter
Hi
I got tyres replaced by Beaurepaires. I tried to see the tyre pressure number on tires but could not find it.
When I call them they said 36psi is the right measurement.
The tyres I got replaced is Dunlop sp sport fastresponse.
NcgOsh is offline
post #4 of 4 (permalink) Old 01-21-2012, 05:49 AM
DEVOURS's Avatar
Quoted: 93 Post(s)
For best results,..go with what is marked on the tag that is on your B Class car. On the tire wall you will see a "max tire pressure" #. Do not set the tires to that pressure.
You are now in the general forum. If you go to the B Class forum further down in Benzworld Forums, you will be able to ask more specific questions on your B 180 model. I feel that you will have many basic questions for us.
Concerning wheel balancing and wheel alignment, they are very different. Your new tires would have been balanced when they were just installed on the rim and should be fine for quite a while.
Balancing keeps your tires from shaking and bouncing while driving. It helps keep better contact with the road with smooth rolling and does this by adding small weights to the edge of the rim or the interior of the wheel to keep your wheel properly balanced.
A wheel alignment keeps your B "tracking" straight on the road. A bad wheel alignment will permit your B to track to the side of the road and towards the ditch,..as a quick explanation.
Go to tirerack.com and search out all of the informative video's and common tire and wheel questions. Their answers will be much better than I can explain here.
DEVOURS is offline
    Correct tire pressure for low profile tire on R129 bkksl R129 SL-Class 13 07-15-2009 08:29 AM
    Tire Pressure. A.N. W245 B-Class 9 10-14-2007 06:06 AM
    taking down tire pressure for 4x4 ing. could you do that on a low profile tire? blau The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 01-06-2006 01:49 PM
    Tire Pressure dee7 The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 06-12-2004 12:59 PM
    Tire Pressure gherman R129 SL-Class 0 09-21-2002 08:58 AM
