2005/2006 E55 AMG - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 01-18-2012, 07:05 PM Thread Starter
Damiiaaannn's Avatar
Date registered: Jan 2012
2005/2006 E55 AMG
Hi everybody. This is my first post here. I'm 16 and will be getting a car in a month or two. I was dead set on a 2012 Camaro SS, but last night I was just doing some more looking around. I found that I could get a 2005/6 E55 with fairly low miles for a little less than the Camaro SS. I just have a few questions about it. Is there any known common problems about the E55? Would an extended warranty be necessary? Also for you CA people, will a tune make the car not pass smog? Smaller pulley? Thats all I can think of right now. If I think of anything else I'll post below.
Damiiaaannn is offline
post #2 of 10 (permalink) Old 02-02-2012, 06:59 AM Thread Starter
post #3 of 10 (permalink) Old 02-02-2012, 07:13 AM
Musikmann's Avatar
Quoted: 5 Post(s)
Try posting on the W211 AMG forum, it doesn't look like anybody is seeing your questions here.
Musikmann is offline
post #4 of 10 (permalink) Old 02-02-2012, 10:14 AM
Date registered: Jan 2011
Vehicle: 1985 190E 2.3-16
Ah, you should look into the maintenance and repair costs. Very good cars, very quick, don't need a tuner because AMG has already done all the performance modifications for you, infinitely more stylish than a new Camaro, but they are not cheap to keep running.
TrapperJohn is offline
post #5 of 10 (permalink) Old 02-04-2012, 08:29 AM
StarPower's Avatar
Date registered: Oct 2009
Vehicle: 2003 Lincoln LS V8
In the 2.5 years I had my CL55 I went from 35,000 to 70,000 mi. These were the engine problems I had (all costs were dealership service unless stated otherwise):
  • Supercharger pulley/clutch bearing (it's not a normal pulley; it uses a clutch to disengage the SC at low speeds): $1320
  • Valve cover gaskets: $430
  • Rear main seal: $1350
  • Spark plugs (2 plugs/cylinder = 16 plugs, so most of the cost is parts): $400
  • Engine mounts: $1280
  • Air injection pump (part of the emissions control system): $950
  • Transmission seal: $160
  • Crankshaft position sensor: $250
  • SC idler pulley bearing: You can buy a new bearing for ~$3 and press it in yourself pretty easily. If you go to the dealer, you have to buy the whole aluminum pulley for about $400.
Most of these are common items on any older car (sensors, seals, bearings), but you can see how expensive they are on one of these engines. You can save a lot of money if you have the time and knowledge to do the work yourself, but parts are still a lot more expensive than they would be for a Camaro.
Also, any high performance car is going to go through wear parts faster than most. Check sites like Tirerack to see what brakes and tires cost. On a daily driven car, plan on replacing the rear tires yearly, the brakes every two years (pads and probably rotors), and the front tires every three to four years (more frequently if you drive the car hard).
Edit: Also, there's not much of a market for aftermarket or used parts for an AMG . I don't know about the new Camaro specifically, but in my experience with other GM cars there are always plenty of sources for inexpensive parts.
StarPower is offline
post #6 of 10 (permalink) Old 02-23-2012, 02:50 AM
Date registered: Aug 2010
Camaro vs. E55
When through same decision between the 2 cars. I'm glad I went with the E55. Much more comfort and style than the new Camaro. I've had my E55 now for 3 years. Only things I've has to replace was transmission pilot bushing (about $20) and tires. It's true you will go through rear tires fast. Every 7 to 12 months. So much torque the computer has a difficult time keeping the tires from spinning. About $500 for a set of rear tires. When shopping for a used E55 make sure the ride is smooth, otherwise there could be a problem with the airmatic suspension. A front strut costs over $1000 to replace. You can have it rebuilt for around $600. I believe this is one of the depreciation factors that dropped the value of a $84,000 car to the mid 20's. All in all a great car though. Great for straight highway use. Kinda like a Lear jet. Hard to keep it at posted speed limits. Good luck.
emonster1 is offline
post #7 of 10 (permalink) Old 02-23-2012, 01:09 PM
Vehicle: 2007 CLK550 Cabriolet, 2006 CLS55 AMG
Send a message via AIM to BrianScottBurns
Thumbs up ALWAYS buy an extended warranty
I recommend to anyone and everyone that is buying a used Mercedes, especially an AMG, to purchase an extended warranty. It might cost around 4K for a 3 year warranty but you will see that cost paid back to you, most likely within the first 12 months. I've noticed with the several Mercedes I have owned over the years that the warranty pays itself off, and most of the time you will see approximately 10K in repairs paid for by the warranty over the 3 year warranty period. NEVER buy a Benz without a warranty. That being said, enjoy the AMG. I'm on my second AMG, this time a supercharged CLS and I LOVE it. Nothing beats an AMG for all out comfort and power. In my opinion, the E and CLS class AMG's are the best all around 4 door sedans on the planet (even if they call my CLS a coupe ;-). Cheers
2006 Mercedes CLS55 AMG
2007 Mercedes CLK550 Cabriolet (AMG Sport Package)
2001 Mercedes CLK430 Cabriolet (AMG Sport Package) (Sold)
2006 Porsche Cayenne S Titanium Edition (Sold)
2000 Mercedes E55 AMG (Sold)
2000 Mercedes C230 Kompressor Special Edition (AMG Sport Package) (Sold)
1994 Mercedes C280 (Sold)
BrianScottBurns is offline
post #8 of 10 (permalink) Old 08-09-2012, 04:13 PM
Date registered: Jul 2005
I've enjoyed my E55 for 3 yrs now. I don't drive it much (it has only 30K mi) but it's always a pleasure. I'd like to have softer tires (smaller wheels) but except for that, it's enjoyable. Very quiet inside, and the supercharged horses are always there in a fraction of a second (much faster throttle response than the newer, normally aspirated models).
doon41 is offline
post #9 of 10 (permalink) Old 08-09-2012, 08:22 PM
Benznoob26's Avatar
Date registered: Jul 2009
Send a message via AIM to Benznoob26
A 16 year old getting a 2006 e55? we need a dreamers section.
Benznoob26 is offline
post #10 of 10 (permalink) Old 08-10-2012, 12:05 AM
AMG Fanatic's Avatar
Date registered: Aug 2012
Vehicle: 1984 280SE Euro, 1988 300SE, 2000 SL500, 2002 CLK55 AMG
Quoted: 10 Post(s)
Wow, 16 years old and deciding between a 2012 Camaro SS and an 06 E55 AMG! Lucky life you got there bud, appreciate it!
I would recommend getting something a little older than those two cars, something from the late 90's to early 2000's with low miles would be my recommendation. The car will be much cheaper to buy and insure.
As for the smog thing, I keep my cars bone stock, and they've never failed a smog test before here in Cali. It mainly depends on what tune you're performing, especially exhaust tunes may impact the emissions.
AMG Fanatic is offline
    2005 vs. 2006 E55 kmode W211 E55 AMG, E63 AMG 4 02-25-2006 02:01 PM
    2006 vs. 2005 SLK AMG Omnipotent R171 SLK-Class 15 08-05-2005 09:32 AM
    2006 or 2005 C55 AMG mzcloud W203 C32 AMG, C55 AMG 9 07-29-2005 12:36 PM
    2006 or 2005 C55 AMG mzcloud General Mercedes-Benz 0 05-31-2005 12:34 PM
    2005.5/2006 C55 mrkbbd W203 C32 AMG, C55 AMG 0 01-05-2005 04:41 PM
