1985 190e Starting problem - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 01-15-2012, 12:05 PM Thread Starter
Date registered: Nov 2008
Vehicle: 1989 300e and 1985 190e
I have a 190e that was sitting for over 3 months while I was in the hospital. I couldn't drive so I started the car a couple of times a week and even drove around the block. I went out yesterday and it started fine and I let it warm up and then turned it off. I went out a couple of hours later and went to start it and it turned over but suddenly everything stopped.After trying several times I noticed the fuel pump was running after I had removed the key so I unhooked the battery cables. I tried to start it several other times but the same thing happened. I looked around and noticed the overload relay fuse was blown so I replaced it but the same thing happened. Where do I start? I have replaced the fuel pump, accumulator and the relay less than a year ago?
Joe BarleY-Maloney is offline
1985 190E throttle valve problem fm2200 W201 190-Class 0 05-17-2011 07:49 AM
1985 190e starting problems and leak Eastsac W201 190-Class 6 01-20-2010 12:33 AM
1985 280ge starting problem mike G-Class 2 08-27-2006 07:11 AM
92 190E 2.3 starting problem planeguy W201 190-Class 2 06-05-2006 04:53 AM
w126 1985 280SE starting problem jinsu W126 S,SE,SEC,SEL,SD,SDL Class 2 03-17-2006 07:08 PM
