1998 C 280 - How to change spark plugs - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 01-14-2012, 08:54 AM Thread Starter
Date registered: Dec 2010
I have a 1998 C 280 that is giving me misfire codes. I got these codes on 2 different cylinders. Once on Cyl # 1 and once on Cyl # 6 . Car has 120k and i purchased with 96k about 3 years ago. I've never replaced spark plugs in this car. I noticed coil has two wires per cylinder. Does it have double ignition? How do the wires remove? Do they just pull off? Don't want to mess anything up. Can anyone advise on how to replace spark plugs?
ophaynes is offline
post #2 of 3 (permalink) Old 01-14-2012, 12:06 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
OBD most often reports symptoms and not the disease.
The most likely cause of these symptoms is failed Mass Airflow Sensor, a common problem on this engine.
You can get an official Mercedes service DVD which explains quite nicely how to replace MAS (and spark plugs, too, if you must).
Star Service CDs and DVDs
Kent Christensen
'07 GL320CDI
lkchris is offline
post #3 of 3 (permalink) Old 01-14-2012, 04:51 PM
Date registered: Mar 2011
Can someone tell me what the trick is to remove spark plug caps on a 91 Mercedes sl300??
blondtonic is offline
    1998 MB C230 Spark Plugs rbmyers W202 C-Class 8 06-14-2011 08:19 PM
    1998 SL500 spark plugs? bj-99 R129 SL-Class 2 03-23-2011 01:52 PM
    Changing Spark Plugs 1998 C280 mbrowntx W202 C-Class 7 05-25-2009 03:26 PM
    Changing Spark Plugs on 1998 C280 mbrowntx W203 C-Class 0 05-24-2009 09:15 PM
    1998 C230 where are spark plugs hiding Guest (MBNZ) W202 C-Class 2 04-07-2002 07:21 PM
