turbo to exhaust manifold gasket directional? - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 01-12-2012, 10:31 PM Thread Starter
Date registered: Feb 2011
SO i did some manifold cleaning, installed EGT probe on my 82 300sd. I immediately ordered a turbo to manifold gasket at the MB dealership, and saw it was puffy on one side and indented on the other. The gasket i pulled off was completely flat, metal. I saw another om 617 at the wrecking yard with a flat gasket of another color, same shape and stud holes.
i replaced the gasket between the exhaust manifold and turbo of my 82 300sd, it is directionally flanged, could not find any info online about how to put it on, ended up putting the puffy side toward the turbo, now i see in my chilton book that this is backwards, engine seems to run fine, should i replace it correctly?
300sd82 is offline
    Exhaust manifold gasket change? Dalesincal R/C107 SL/SLC Class 3 04-11-2010 08:55 AM
    E320 CDI Exhaust manifold Gasket??? gruffy W210 E-Class 3 01-16-2010 09:37 AM
    Exhaust manifold/gasket problem! bielefeld280se W126 S,SE,SEC,SEL,SD,SDL Class 2 09-09-2008 10:15 AM
    Intake&exhaust manifold gasket part ## lander91 W126 S,SE,SEC,SEL,SD,SDL Class 0 01-07-2006 07:09 PM
    blown exhaust manifold gasket 3199cc C208/A208 CLK-Class 1 10-06-2004 07:20 PM
