ML320 2000 W163 - electrical problems after jump-starting the battery - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 01-10-2012, 05:24 AM Thread Starter
Date registered: Jan 2012
Vehicle: 2000 ML320 W163 White with grey leather interior
Send a message via Skype™ to WaldoViljoen
Question ML320 2000 W163 - electrical problems after jump-starting the battery
My ML320 2000 model was jump-started without any precautions done to compensate for the influx of power, since then I experienced :
1. No Central Locking (have checked all fuses) and tried resetting without luck...
2. ESP/ABS/SRS Lights being on permanantly - and having no AWD, it swervs on the road, braking bad, no power steering...
3. Flickering ON-OFF dashboard indicators with handbrake-alarm sounding especially in wet weather and after hitting water puddles.
Please help.
Please give me the Central locking reset instructions
WaldoViljoen is offline
post #2 of 3 (permalink) Old 01-10-2012, 05:31 AM
Musikmann's Avatar
Quoted: 6 Post(s)
You have a lot more to worry about than the central locking. Troll around on the W163 forum and/or have the car scanned for the diagnostic codes. My best guess is you fried one (or more) of the relays or control modules. Sorry to hear that and good luck.
Musikmann is offline
post #3 of 3 (permalink) Old 01-10-2012, 09:08 AM
Kajtek1's Avatar
Quoted: 1226 Post(s)
Ditto on bad feeling about this. Did you charge, tested the battery after the jump?
Try to disconnect the battery (key off) and by pushing the brakes drain all remaining power and than reconnect TESTED battery.
Kajtek1 is offline
    Suitable ground point when charging battery/jump starting? autoque W221 S-Class 8 09-06-2011 04:51 AM
    Jump Starting, Battery connectors locations LuisR R171 SLK-Class 2 07-22-2010 11:24 AM
    ML320 2000 Starting Problems dshear@iname.com General Mercedes-Benz 4 03-21-2010 01:30 PM
    Hi, 2000 ml320 with electrical plate problems bjbrath General Mercedes-Benz 3 09-10-2009 02:37 PM
    Serious problems after jump starting... BMWebb W140 S-Class 11 12-30-2007 01:51 AM
