2009 E Class radio retrofit - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 01-08-2012, 08:04 AM Thread Starter
Date registered: Jan 2012
Vehicle: 2009 e 350 Sport Trim
I am in process of acquiring a 2009 e 350 sport from a colleague. It has the "standard" radio; I would like to upgrade/retrofit to the "premium 1" package radio (satellite, HD radio, ipod interface, HK Logic 7, and navigation). I sense there is quite a bit more than just purchasing a new head unit.
1. Can such a retrofit be done by a MB dealer?
2. How much (approx.) will it cost? $1k, 2k, #3k, +++?
3. Will I be satisfied with the result, or should I just look for a car with the preimum 1 package?
I have searched the forums and cannot find a satisfactory answer. I would like to keep the car as factory original as possible, ie, no aftermarket units unless absolutely required.
jack wilson is offline
post #2 of 3 (permalink) Old 01-08-2012, 08:50 AM
Musikmann's Avatar
Quoted: 5 Post(s)
Try a search the W211 forum (sedans sub-section) because this has probably been discussed. You might also find your answer on the Audio & Telematics forum in the Technical sub-section. Good luck and welcome to the forum.
Musikmann is offline
post #3 of 3 (permalink) Old 01-08-2012, 05:48 PM
Date registered: Mar 2006
Vehicle: 2005 CL65 AMG, 2007 Ferrari F430
If the car already has the Harmon Kardon speakers, the COMAND is a drop in replacement. Then you can add everything else easy. If it does not have the HK speakers, then it is a big job!
InCarTronics is offline
    2009, retrofit OEM LED tail lights help! lumibenz W164 M-Class 6 07-09-2011 12:43 PM
    2009-10 oem navigation radio on 2006 r-class sivajenny1 W251 R-Class 9 03-08-2010 06:21 PM
    Radio retrofit Help HOPE C208/A208 CLK-Class 3 11-16-2009 09:19 PM
    2009 ML63 Front & Rear Bumper Retrofit on 08 ML550 speed16 W164 M-Class 1 07-15-2009 03:55 PM
    Mercedes C Class and M Class IIHS Top Safety Picks for 2009 MY2008ML350 MB Safety & Testimonials 2 12-02-2008 01:03 PM
