Alignment needed? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 01-06-2012, 12:47 PM Thread Starter
Date registered: Mar 2011
Vehicle: Mercedes Benz C300 Sports 4matic, Year 2011
Quoted: 6 Post(s)
Unhappy Alignment needed?
I have recently changed my rear 2 tires of my 2006 C230 at Costco. I have noticed that after I feel a kind of slight skidding like thing when I am driving specially on highways at high speed. I feel a little pull on the steering wheel also.
Can you tell me what this is because of? Do the wheels needs alignment? or is it something else? Or do I need to change my front tires as well, so that all the 4 tires are same and new.
Also is it worth to do the alignment at the dealers where they charge $175 whereas AAA or even Honda dealer charge around $50-60.
I do not want to spend the money doing alignment and see the problem is still not solved.
Any suggestions, experts?
Thank you guys
Winston Salem, NC
debargha is offline
post #2 of 3 (permalink) Old 01-06-2012, 01:30 PM
Date registered: Sep 2011
Vehicle: 2003 SL 500
The very first thing you need to do is swap the two front wheels and see how it drives. Simple and easy. If no improvement then take it to a really good front end shop- not Firestonemor one of those places.
Jfscars48 is offline
post #3 of 3 (permalink) Old 01-07-2012, 12:28 PM
Musikmann's Avatar
Quoted: 5 Post(s)
Ditto, try putting the new tires on the front wheels and the older ones on the rears and see how the car behaves. But I don't see how changing only the rear tires would affect the front end alignment. Personally I always buy all 4 new tires at the same time partly because I have them rotated regularly and they wear out at about the same time.
Musikmann is offline
    Alignment Needed Periodically ryunk W163 M-Class 8 02-13-2011 03:49 PM
    Alignment needed after UCA change? Firewater W126 S,SE,SEC,SEL,SD,SDL Class 13 08-31-2010 10:50 AM
    Car started pulling to the right - alignment needed? W210 E-Class 8 09-18-2009 02:54 PM
    Help needed with front wheel alignment A1EK W210 E-Class 2 05-30-2007 02:44 AM
    Alignment specs needed Tom Deckowski G-Class 10 03-05-2004 02:38 PM
