'81 300D won't start, just replaced starter - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 01-04-2012, 05:19 PM Thread Starter
Date registered: Jan 2012
Vehicle: 1981 Mercedes 300D, 1985 Mercedes 300TD Wagon
1980 300D won't start. Would sometimes start after 5-10 attempts and jiggling the shifter. Just replaced starter and now doesn't start at all. Fuse is fine. What else can I try? New ignition coil? New switch?
Nomadik79 is offline
post #2 of 4 (permalink) Old 01-10-2012, 10:40 AM Thread Starter
Anyone have any advice???
post #3 of 4 (permalink) Old 01-13-2012, 12:47 AM
Date registered: Sep 2009
fuel pump or clogged fuel filter....if the car turns over but wont fire up likely the problem. Starter issue would be easily identified by this difference if the car is turning over and trying to fire up it's a fuel supply issue or compression issue.
IF the car when you turn the starter over just clicks and you put boosters on it still having same problem this would be a starter issue.
Since the starter is replaced try the prior to resolve the issue....also check that glowplugs aren't clogged and in need of replacement.
Many companies build cars...But only one company built THE CAR, with 125 years of tradition and innovation only one name started it all...Mercedes Benz
benijaunah is offline
post #4 of 4 (permalink) Old 01-13-2012, 08:54 AM
Kajtek1's Avatar
Quoted: 1163 Post(s)
I am confused.
Is it that engine is turning and will not start, or the starter in not turning the engine?
Kajtek1 is online now
    Replaced starter...still no juice to it.... LovingTheInsectorcist W123 E,CE,D,CD,TD,TE Class 5 08-11-2009 09:31 PM
    Anyone replaced a starter on an ML320 ? geordie W163 M-Class 5 04-09-2008 11:06 PM
    Replaced starter but still problems??? bbri4570 W124 E,CE,D,TD Class 5 02-28-2008 02:06 PM
    83 300D Wont start, no click - Starter? durado W123 E,CE,D,CD,TD,TE Class 7 09-26-2007 03:40 PM
    Starter and Solenoid replaced Ed Mclass G-Class 2 10-14-2002 10:46 AM
