2003 311cdi. Starting problems - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 01-04-2012, 07:54 AM Thread Starter
Date registered: Jan 2012
My problems are intermittent.
Vehicle runs fine for several days then after stopping for a short time, the engine turns over, fires and immediately cuts out. It always seems to turn over very well and fires for a short time on every second or third attempt but will not continue to run.
This has happened a few times now and I have had to recover the vehicle only to find that a few hours later it starts perfectly.
The only other symptom is that occasionally, on first start in the morning, revs seem limited to about 3000rpm, but then clear for no apparent reason. Our local Mercedes repairer has tried computer diagnosing, but no faults show up and because of the very intermittent nature of the problem, up to now no fix has been discovered.
Recently, I have had a new Starter Motor, Ignition Switch and one Injector changed.
Ivacon is offline
    2003 Sprinter 311CDi Air in Fuel iain_ogilvie W901-905 Sprinter 4 02-17-2012 12:58 PM
    2003 311cdi. Starting problems Ivacon Test 0 01-04-2012 07:15 AM
    Retrofix cruise control to a 2003 Sprinter 311Cdi? dicko99 W901-905 Sprinter 1 07-19-2011 07:40 AM
    2003 clk convertible 240 starting problems desp C209/A209 CLK-Class 6 10-03-2010 05:49 PM
    311Cdi Overfuelling and poor starting. cnics W901-905 Sprinter 0 12-20-2008 04:50 PM
