Tires on '80 MB 450SL? - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 01-03-2012, 11:36 PM Thread Starter
JHanson907's Avatar
Date registered: Dec 2011
Vehicle: 1980 450SL; 1988 560SEL
Quoted: 8 Post(s)
We have a very nice condition 1980 MB 450SL w/ 66k original miles on it. No rust problems evident (not even in the forward engine wells). Minor wear in the interior. Everything works. Strong engine, transmission, etc., including factory size tires (newer, but on 14" chrome spoke knock off type wheels). Would like to put on 15 inch wheels and wider tires.
Question #1: What is the widest (safe) recommended tire width for this car?
Question #2: What are some aftermarket wheel manufacturers for after market wheels for this car? So far, I have found the available market quite limited.
Question #3: The rear end on this car tends to squat just a bit compared to the front end. Recommended ideas on correcting this problem? Would a different wheel size on the rear compared to the front be a recommended way to correct this issue? Is it an issue at all?
Question #4: Has anyone swapped out the original seats for Reccaro easy-in/easy-out type of (leather) seats? Any problems encountered w/ this change out?
Thank you for your help. This is our first MB and we love driving and owing it very much. Sunny days in Alaska just aren't the same anymore. They are much better!
JHanson907 is offline
post #2 of 2 (permalink) Old 01-04-2012, 07:54 AM
eric242340's Avatar
Quoted: 283 Post(s)
Welcome to Benzworld. If you follow the following tips then you will get the most out of this forum, please enjoy the forum.
Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see Benzworld help here: - Mercedes-Benz Discussion Forum - FAQ: General Forum Usage
Benzworld help is for general enquires and all technical questions should be posted on the specific forum for your car. If you are not sure which forum it should be on then please ask me and I will give you a link.
eric242340 is offline
    tires for MB1978 450SL Steele Vintage Mercedes-Benz 1 05-26-2005 01:25 PM
    Tires for 1979 450SL johnregnery R/C107 SL/SLC Class 5 12-06-2004 07:15 PM
    Tires for a 1979 450SL johnregnery The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 11-30-2004 12:02 PM
    Tires for 1979 450SL johnregnery R/C107 SL/SLC Class 0 11-29-2004 01:00 PM
    Tires for 450SL? GjC R/C107 SL/SLC Class 2 01-30-2003 06:34 PM
