Alignment Problem on 300TE and 300D - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 01-03-2012, 05:08 PM Thread Starter
Date registered: Jan 2012
Vehicle: 1992 300TE Wagon, 1983 300D Turbo Diesel
Hello, we've just purchased a 1992 300TE wagon (200,000 miles) to join our 1983 300D Turbo (300,000). My husband is a mechanic at Goodyear and took the car in today to have new tires put on, balanced, and aligned.
The 300TE pulled a little to the right before the alignment, and still pulls to the right after aligning. The steering wheel also does not sit straight when you are driving straight down the road, you have to keep it turned slightly to the left.
Interestingly enough, we have the exact same problem with our 300D.
Is there something special about Mercedes alignments that my husband needs to know to get both of these cars aligned correctly? He did notice that the sway arm bushing needs to be replaced in the 300TE, but that does not apply to the 300D.
Thanks in advance for any replies.
nearthemagic is offline
post #2 of 4 (permalink) Old 01-03-2012, 05:49 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
Can you clarify whether the cars were aligned to specs, but the symptoms persisted or can he not get the alignment to go within specs?
flyboyike is offline
post #3 of 4 (permalink) Old 01-03-2012, 06:00 PM Thread Starter
The cars were successfully aligned to specs, but both still pull to the right.
post #4 of 4 (permalink) Old 07-22-2012, 01:48 PM
Bimmerman4ever's Avatar
Date registered: Jun 2009
Vehicle: 99 Audi A8 Quattro 4.2 & 00 E320 4M
Quoted: 17 Post(s)
Post
Ever figure out the issue?
Give it a +1 on the right camber? (I've read that works, since shops try to spec it in the middle)
Or maybe it was a rear arm bushing???
My 300TE 4MATIC is doing that, though I figure it might be the warn out tires.
Before I give it an alignment, and/or mount new tires, I will wear down the old tires first.
Past Euros: 91 MBZ 300TE, 91 Jaguar XJS V12 Coupe, 94 Alfa Romeo 164 LS, 80 BMW 320i, 85 BMW 528e, 86 BMW 325e, 88 BMW 325e, 88 BMW 325i Cab, 89 BMW 325ix, 91 325i Cabrio, 93 BMW 740i, 94 BMW 740iL, 95 BMW 525i, 78 Fiat Spyder 124, 98 Land Rover D1 LSE, 93 MBZ 190E 2.6, 96 MBZ C280 Sport, 93 MBZ 400E, 90 MBZ 300ce, 92 MBZ 500SL, 71 MGB-GT, 91 VW Corrado G60
Bimmerman4ever is offline
    Parting out '95 E320 sedan & wagon, '93 300E 2.8, 92 300TE 4matic, '92 300D, '87 300D David Hendy For Sale/Wanted/Trade/Giveaway 63 07-18-2013 07:31 PM
    300D, 190E 2.3-16V, 300TE, 300TE, 4-Matic Parts Cars David Hendy For Sale/Wanted/Trade/Giveaway 22 02-25-2012 08:51 PM
    Question on '85 300D Alignment turboJOB General Mercedes-Benz 3 12-08-2010 03:27 PM
    2x Benzs for 9k 83' 300d turbo & 90 300te doucy2 For Sale/Wanted/Trade/Giveaway 0 09-20-2006 03:02 PM
    '81 300D - Pulley alignment Belvario W123 E,CE,D,CD,TD,TE Class 8 12-07-2003 05:16 PM
