300te rear shock retrofit - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 01-03-2012, 08:54 AM Thread Starter
Date registered: Mar 2011
After reading the forums here on what to do with my 89 wagon failed rear shocks, I researched alternatives to the hydro system as the value of the car did not warrant new units.
I went on the Monroe website and found a pair of air shocks that fit with minimum hassle. they are part # MA705 and cost $57.00/pair
You need to drill a 7/16 hole in the lower A-arm and do a little grinding/hammering around the shock tunnel for clearance on the upper shock tube. Took me about 3 hours to complete and the car is now better than before. You can set the ride height anywhere you want it, ( I use 90 psi).
This works and can save a lot of wagons a premature death as the new hydro units ( and all the other parts that go bad ) are expensive.
woodboat dave is offline
post #2 of 2 (permalink) Old 01-03-2012, 02:39 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 67 Post(s)
Well, the most common failure mode on those cars is not the failure of the shock itself, but of the air cell. Those are around $100 a piece. The shocks themselves are around $400 a piece and if a car is not worth that, I'm not convinced it's worth messing with at all.
flyboyike is offline
    Retrofit rear roller blind bnam W204 C-Class 0 10-09-2011 07:02 AM
    Rear Fold Down Seats Retrofit dreamline W211 E-Class 7 08-17-2010 06:46 PM
    Rear Suspension Help - 300TE Clunks at Rear erikrb W124 E,CE,D,TD Class 0 03-21-2009 06:12 AM
    One more rear shock question: Labor time to install Bilstein shocks in the rear? HACK THT W163 M-Class 9 08-16-2008 10:40 AM
    rear wiper motor, rear lenses and hood felt wanted for W124 (88 300TE wagon) davidascher For Sale/Wanted/Trade/Giveaway 4 07-24-2007 06:30 PM
