static noise while moving only... - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 12-28-2011, 11:17 AM Thread Starter
Date registered: Dec 2011
Vehicle: 2001 C240
Hello everyone... I have a 2001 c240 and i noticed what seem like a static noise whenever my car is moving only... it sounds like a small motor running... it stops when i stop and the sound goes faster as speed increases... told a friend to take a listen while we're driving he said he can hear it coming from my side meanwhile i can hear it coming from the passenger side... have anybody had this kind of problem or knows what this sound is coming from?
angelju2001 is offline
post #2 of 5 (permalink) Old 12-29-2011, 12:50 AM
eric242340's Avatar
Quoted: 296 Post(s)
The best place to ask this question is on this link;
W203 C-Class - Benzworld.org - Mercedes-Benz Discussion Forum
But take a listen to the upper control unit, this is the interior light above the rear view mirror, inside this is a small electric fan that blows air over the "in-car" temperature sensor and often this little fan becomes clogged with dust and needs cleaning.
ERIC.
eric242340 is offline
post #3 of 5 (permalink) Old 12-29-2011, 04:20 PM Thread Starter
Vehicle: 2001 C240
will check the and try that Eric... thank you very much for the advice...
post #4 of 5 (permalink) Old 12-29-2011, 04:55 PM
Hi From New Mexico. Recently bought a near pristine 1973 280C coupe. Many small niggly things need fixing like the trip meter and mileage though the speedometer works fine. Can't get the window washer to work. And a few other similar problems. but runs like a top. Getting apprx. about 19 mpg and am using the car as a daily driver. since I'm retired I don't do a huge amount of driving. also has the car re-undercoated so I could reasonably drive in inclement weather.
alan2a is offline
post #5 of 5 (permalink) Old 12-30-2011, 01:17 AM
eric242340's Avatar
Quoted: 296 Post(s)
Welcome to Benzworld. If you follow the following tips then you will get the most out of this forum, please enjoy the forum.
Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see Benzworld help here:
http://www.benzworld.org/forums/faq.php?faq=vb3_board_usage#faq_vb3_thread_display
Benzworld help is for general enquires and all technical questions should be posted on the specific forum for your car. If you are not sure which forum it should be on then please ask me and I will give you a link.
Regards
    static noise in spkeakers Bystrov W140 S-Class 11 08-19-2010 10:09 AM
    W169 vibration noise when moving off and a seperate purring noise swiftguy W169 A-Class 1 10-13-2009 06:37 AM
    Static noise coming from CD changer annyoung Audio & Telematics Forum 8 09-03-2007 07:13 PM
    static noise on AM radio stations ajimsr W163 M-Class 2 02-19-2005 02:33 PM
    Intermittent Static Noise filmfun W220 S-Class 0 06-27-2004 02:49 PM
