Blower Motor seized up - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 12-28-2011, 09:09 AM Thread Starter
Date registered: Nov 2011
Vehicle: 1994 Mercedes-Benz S420
Question Blower Motor seized up
Hi Everyone.
I have a 1994 S420 and the blower motor has stopped working. We did a temporary fix by lubricating the motor with ATF, but it has stopped working again and will need to be replaced. I have found that this is not as daunting a task as it is in many other cars, but I need to make sure I get the correct motor. I am fearful of ordering anything after-market because it seems NOTHING on this car will accept an after-market part--at least, nothing I have replaced so far.
Can anyone provide me with the actual manufacturer part number for the blower motor? I have found several online (some with plastic fans) and just need to know which one to get. I don't have a bunch of money to spend, so if anyone can direct me to a place I can get one, I will be so grateful.
SilverQueen is offline
post #2 of 5 (permalink) Old 12-29-2011, 07:48 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 67 Post(s)
Your Parts Search Returned 1 Part(s)
flyboyike is offline
post #3 of 5 (permalink) Old 12-29-2011, 08:36 AM
Kajtek1's Avatar
Quoted: 1068 Post(s)
Welcome to the forum. If you are DIY, the usual old motor failure is wear out brushes. Those to same degree are serviceable, although MB is not selling them separately. Check your model section, maybe somebody already did it, or I know we do have a pictorial for the job in W210 section.
Kajtek1 is online now
post #4 of 5 (permalink) Old 01-15-2012, 09:20 AM Thread Starter
Ok. Got the motor.
Originally Posted by flyboyike View Post
I got the motor from azautohaus and now we cannot get the sq2uirrel cage off the old motor. We have tried busting the motor to drive the shaft out the top of the fan, everything. Cannot get it off of there. Now I need a squirrel cage. None of the parts listings have just a fan. Have a suggestion for me?
post #5 of 5 (permalink) Old 01-15-2012, 09:52 AM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T current 2014 lexus LS460
That is a common problem, the motor shaft is rusted to the squirrel cage, maybe auto Hauz will allow you to return it and get the entire assembly, or try and get one from Eddie who sells good used parts on this site
Peter Guenther is offline
    Blower not working but blower motor fine what to check next? classicchic W123 E,CE,D,CD,TD,TE Class 20 05-07-2014 05:56 PM
    W126 separate blower from blower motor? curtesy W126 S,SE,SEC,SEL,SD,SDL Class 6 02-02-2013 02:21 PM
    1998 W210 E300DT Bad Blower Regulator or Blower Motor?? How to tell DieselNuts W210 E-Class 12 08-16-2012 09:32 AM
    190D won't start after seized alternator stopped the motor Felix123 W201 190-Class 13 03-26-2011 06:34 PM
    Blower Motor + Burning Smell = No Blower Motor nuts2that W210 E-Class 6 07-28-2010 01:07 AM
