1980 380SEL stalling problem - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 12-24-2011, 07:14 PM Thread Starter
Date registered: Dec 2011
I have a 1980 380SEL. It fires right up, idles for about 2 seconds, then dies. Eventually it stays running, but you can't step on the gas or it will die. Once it's warmed up and will drive, it dies at random. It also doesn't seem to have the power that it should. I bought it from a student in the auto mechanics program at the local technical college. He did a tune up on it (plugs, wires, cap, timing, etc). He said he drove it to IL one time and it started acting up after that (700 mile round trip). I have 12 volts at the fuel pump and it seems to be working fine. I have a dvd manual. The troubleshooting on that told me to test the idle air controller. It tested fine. I was thinking maybe low fuel pressure, but I don't know - I'm not a Mercedes mechanic. I've worked on cars all my life but there's a lot of doodads on this one that I don't recognize and I can't read the German. But I really like the car and want to drive it. Is there any way to test for the low fuel pressure? Any help would be greatly appreciated.
shmutzmonkey is offline
post #2 of 3 (permalink) Old 12-25-2011, 05:07 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 67 Post(s)
Yes, there is. If anything, that car has considerably fewer doodads than most, but I digress...
Read here about how the injection system operates:
flyboyike is offline
post #3 of 3 (permalink) Old 12-25-2011, 07:48 AM Thread Starter
Thank you for your response! I read the information and will check out the fuel system.
    1980 AMG 380SEL EURO osprey170 W126 S,SE,SEC,SEL,SD,SDL Class 23 02-11-2009 03:52 PM
    1980 240d stalling at speed - solutions? stephanjt W123 E,CE,D,CD,TD,TE Class 5 09-14-2008 07:39 PM
    Vacuum timing advance problem on an '81 380SEL cockatoo W126 S,SE,SEC,SEL,SD,SDL Class 13 03-07-2007 01:10 AM
    Help With Fuel Problem In My 82' 380sel brenman8 W126 S,SE,SEC,SEL,SD,SDL Class 7 02-06-2007 07:44 AM
    Fast Idle problem 82 380SEL Carl_Boehme W126 S,SE,SEC,SEL,SD,SDL Class 3 11-29-2003 06:38 AM
