transmission fluid in coolant/95 c200 m111.941 - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 12-22-2011, 02:59 PM Thread Starter
Date registered: Dec 2011
Ok, So I had a head gasket blow and they replaced it, along with various smaller parts, and this charge was just under 700usd. In Malaysia, Chinese shop in Penang. The guys said drive it for a while with only water in the cooling system before you put in coolant to clean it out. So I drive for two days, and each morning when the engine is cool I unconnect the radiator hose on the bottom and drain out the water. And for two days it has milkshake, see photo with water and clean oil on left bowl. New Milkshake on right bowl. ( more red than the previous chocolate milkshake which was in the oil before the top overhaul) in it. So, I think shit, he didnt' do this correctly. I go back and he says "this looks like transmission fluid in the cooling system and I will put a rebuilt radiator on and try it". This for about 100usd with fluid. So I am keeping my fingers crossed. I am wondering if somehow they broke the radiator somehow doing the head gasket replacement? "He said the engine is ok, I'm sure"
Here is the list of repairs during head gasket replacement;
1. Engine Oil 40.00
2. Filter 9.00
3. Top overhaul kit. 170.00
4. Thermostat. 22.00
5. Head Screw 12.00
6. Breather Hose and Pipe 25.00
7. Water Jacket 80.00
8. Belt Absorber 27.00
9. Labor, skim head, etc 280.00
Any knowledgable comments welcome.
Name:	oil on cooling system 001.jpg
starpony is offline
post #2 of 3 (permalink) Old 12-23-2011, 02:57 AM
eric242340's Avatar
Quoted: 283 Post(s)
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see Benzworld help here: - Mercedes-Benz Discussion Forum - FAQ: General Forum Usage
Benzworld help is for general enquires and all technical questions should be posted on the specific forum for your car. If you are not sure which forum it should be on then please ask me and I will give you a link.
eric242340 is online now
post #3 of 3 (permalink) Old 12-24-2011, 01:24 AM Thread Starter
problem solved. radiator leaking in the transmission cooling sector.
starpony is offline
    Coolant-transmission fluid mix - how? ppp111 W140 S-Class 7 05-30-2010 11:32 AM
    Difference between c200 m111 and m271 benz111 W203 C-Class 1 11-19-2009 07:27 PM
    Transmission fluid foaming / coolant? jshood W210 E-Class 9 01-22-2009 10:08 PM
    automatic transmission fluid C200 CDI yacinebenhadj W203 C-Class 0 01-14-2009 08:48 AM
    engine coolant & transmission fluid ericlee R/C107 SL/SLC Class 9 07-26-2008 10:12 AM
