W126/Diesel battery choices - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 12-21-2011, 06:35 PM Thread Starter
Date registered: Jan 2011
I recently got a 1985 300SD. The car came with an undersized battery (I think 600CCA) that the previous owner had installed. Well, after draining the battery over 4 months with the aftermarket stereo (I was at school), it's dead and I need to replace it. I live in New England.
The stock size is Group 49. Those batteries are about 850CCA. I went to a Rayovac dealer today and found one. But, they also had a truck battery (I forget the size) that rates at 1150CCA. Dimensionally it was about the same, except it was about 1/2" taller than the 49.
The truck battery is about $20 cheaper (I have a commercial account).
I want to try to put the bigger battery in and see if it fits. As long as I run the vent hose under the car, is there any reason I should NOT try to do this?
Greyhounds is offline
post #2 of 3 (permalink) Old 12-21-2011, 07:36 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 67 Post(s)
Well, there is no reason why not, but then why not buy TWO 1150CCA batteries and run two vent hoses etc etc? After all, don't diesel trucks have at least two batteries?
Actually, allow me to rephrase: are you the "use a sledgehammer to nail in a thumbtac" kid of guy? Not that there is anything wrong with that.
flyboyike is offline
post #3 of 3 (permalink) Old 12-22-2011, 09:21 AM
Kajtek1's Avatar
Quoted: 1064 Post(s)
Only big diesels have dual batteries.
Is W126 battery mounted under the seat that you need vent tube?
I was fortunate to find tubed battery for our W210 at Costco for $80. Than for my diesel truck that has batteries under the hood, I bought 1000 amp Costco batteries for about $55 each. 100 months warranty.
Kajtek1 is offline
    W126 Diesel and Bio-Diesel forum section? Benellipaul W126 S,SE,SEC,SEL,SD,SDL Class 8 05-27-2012 07:39 AM
    W126 coupe euro headlight/tail light/exhaust choices compared side by side (pic's) cascade W126 S,SE,SEC,SEL,SD,SDL Class 66 03-09-2010 01:21 AM
    Engine weights/Choices for W126 Powerplant DAW W126 S,SE,SEC,SEL,SD,SDL Class 6 05-06-2008 02:14 PM
    What battery do you have in your W123 Diesel ? 55Gullwing W123 E,CE,D,CD,TD,TE Class 28 04-02-2006 08:07 PM
    Diesel battery replacement Cyberbach W124 E,CE,D,TD Class 2 09-15-2005 11:21 PM
