Help! Transfer Case/Transmission Issues!!! - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 12-13-2011, 11:51 AM Thread Starter
veloette-ML's Avatar
Date registered: Jun 2011
Vehicle: 1999 Benz. ML430, 2006 Toyota Avalon, 2002 Jag. S-Type (sold), 1985 Benz 380-S
Red face Help! Transfer Case/Transmission Issues!!!
I have a 1999 ML430 that have a Transfer Case+Transmission Issue. My TC was making noise and felt like it was slipping. I purchased a TC from a 2005 ML350 very low mileage. The TC have been switched out, and my original problem went away...everything is quiet and smooth now. BUT, after everything is carefully put back together, it seems the TC is locked in "Low Range", the Transmission won't shift thru the gears, and my "Low/High Range" button lamp won't come on and don't have any effect on anything? I wonder if I will have to exchange my old TC-motor with the new used-one?
I've Double checked the connector, it connected right up to the new used-one? Is their anybody familiar with an issue like mine's? Is their something I missed...Is their something I need to check/do at this point...EXCEPT CALL IN THE BIG GUNS (the dealer/repair shop)??? Thank you'all in advance!
veloette-ML is offline
    Tranfer Case projectwoa For Sale/Wanted/Trade/Giveaway 0 12-17-2008 07:16 PM
    Case PTO Pump Issues MogMountain Unimog 3 07-28-2008 05:43 AM
    Tech Question about G500 Tranfer case Scottgs G-Class 0 11-22-2005 11:10 AM
    Tranfer Case Problem bwillie G-Class 8 07-19-2005 07:08 AM
    Found the bad bearing in the tranfer case! Gerald A G-Class 4 06-16-2003 08:26 AM
