2009 s550 ac vents - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 12-06-2011, 03:18 PM Thread Starter
Date registered: Dec 2011
2009 s550 ac vents
I have a 2009 s 550 cpo car, still in warranty, while trying to activate the heater, on auto climate control, at 76 degrees, no air from middle dash vents.
the dealer told me this is normal, is that true? I have also noticed the when set at 72 degrees, the passenger vent barely lets air pass.
is this normal?
thanks
Texas777 is offline
post #2 of 6 (permalink) Old 12-07-2011, 04:46 AM
eric242340's Avatar
Quoted: 300 Post(s)
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see Benzworld help here:
Benzworld.org - Mercedes-Benz Discussion Forum - FAQ: General Forum Usage
Benzworld help is for general enquires and all technical questions should be posted on the specific forum for your car. If you are not sure which forum it should be on then please ask me and I will give you a link.
Remove the AC filter and see if you get more air from the vents, quite a common problem with blocked filters.
Regards
ERIC.
eric242340 is offline
post #3 of 6 (permalink) Old 12-07-2011, 08:46 AM Thread Starter
air filter is new
supposedly, the ac filter was replaced by the dealer when cpo work was done, along with odor removal, and disinfecting the venting system.
that was 3500 miles ago.
how do i go about removing the ac filter to inspect it?
thanks in advance,
Ross
Texas777 is offline
post #4 of 6 (permalink) Old 12-07-2011, 06:03 PM
eric242340's Avatar
Quoted: 300 Post(s)
Very easy to do;
ID:	414236   Click image for larger version
ERIC.
post #5 of 6 (permalink) Old 12-07-2011, 06:05 PM
eric242340's Avatar
Quoted: 300 Post(s)
I forgot, remove the cover first, two screws (2)
ERIC.
post #6 of 6 (permalink) Old 12-07-2011, 07:23 PM Thread Starter
thanks , will give it a try and report
Texas777 is offline
    2009 cl550 4matic vs 2009 s550 4matic - transfer case haik W221 S-Class 2 06-06-2010 07:07 PM
    ipod with 2009 s550 rich14 Audio & Telematics Forum 1 09-15-2009 08:23 AM
    Why does a 2007 S550 get better gas mileage then the 2008 and 2009 S550? laxexquis W221 S-Class 2 04-26-2009 12:53 PM
    2009 S550 Lease blevan W221 S-Class 12 04-03-2009 04:04 PM
    New to Forum: 2009 S550 LGV General Mercedes-Benz 2 07-01-2008 03:46 PM
