2000 c280 starting problem - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 12-03-2011, 05:56 PM Thread Starter
Date registered: Dec 2011
I have a 2000 C280 that began having intermittent starting problems a while back. The problem has gotten much worse and now the car is almost un-drivable.
The car has the 2000 vintage all black 3 button FOB for a key. Normally when the key is placed in the ignition a whooshing sound unlocks the ignition and allows the key to be turned. My problem is that the key only unlocks the ignition every once in a while (meaning you have to keep putting the key in and out of the ignition until you hear that unlocking sound...and then the car starts fine).
So far, I have replaced the key FOB batteries. I tried re-syncing the key to the car (push 5 times procedure) and also tried swapping in a new car battery. None of this has made any difference. I only have 1 carkey (since my son dropped the second in the harbor) so I can't try the obvious "try the other key" troubleshooting method.
I will go to the dealer if I have to but I'm also willing to try a few ideas if anyone has suggestions. Should I buy a new key from ebay and have the dealer program it to the car? Should I think about replacing the ignition unit on the dashboard?
Thanks for reading.....keep_it_running
Sorry for placing the post here....newbie mistake....mods, delete if needed since I reposted in correct place
Last edited by keep_it_running; 12-03-2011 at 06:02 PM. Reason: posted in wrong area
keep_it_running is offline
Starting Problem 95 C280 johnt671 W202 C-Class 6 06-22-2011 11:58 AM
A/C Heater Blower problem 2000 C280 guapo W202 C-Class 0 07-06-2010 01:34 PM
C280 warm starting problem jbutze W202 C-Class 7 12-03-2007 07:00 AM
2000 S320 CDI Starting Problem jenky W220 S-Class 1 02-09-2007 09:24 AM
c280 starting problem dewallace W202 C-Class 2 05-12-2006 11:01 AM
