1968 250 S leaking diff. fluid.. HELP!! - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 12-02-2011, 11:22 PM Thread Starter
Date registered: Dec 2011
Unhappy 1968 250 S leaking diff. fluid.. HELP!!
Im in need of some help with my mercedes.. I have a 1968 250 S in very good condition but I have an issue with the drivers side rear brake/axle. Its leaking differential fluid from the axle seal
I just need help on how to change the seal and bearing because I don't know if the axle is hooked in by a pin to the differential or if it just presses into the differential?
Someone please help me as I need to sell the car and can't sell it with a leaking axle seal!! If anyone knows of any sites or other posts that have instructions on how to change the rear bearing and axle seal in a 1968 250 S it would be greatly appreciated!!!!
NickL61891 is offline
    Rear diff leaking? rriggi129 R129 SL-Class 4 09-07-2011 07:50 AM
    diff leaking WANTAMB W123 E,CE,D,CD,TD,TE Class 11 11-05-2010 04:20 PM
    second hand Diff. Leaking at the nut. Olivier A W210 E-Class 22 09-19-2009 02:02 AM
    trans fluid and diff fluid replacement cost? numitor R170 SLK-Class 10 07-28-2007 09:40 PM
    How often to change transmission fluid-filter and diff fluid? Ramesh W126 S,SE,SEC,SEL,SD,SDL Class 11 08-17-2006 04:31 PM
