1985 380sl heater problem - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 11-27-2011, 03:08 PM Thread Starter
Date registered: Aug 2011
Vehicle: 1985 380sl
My ac control unit blows cold but when I roll the temp control to gain heat I don't get any heat. Any thoughts?
Thanks
Bob
Penzbenz is offline
post #2 of 4 (permalink) Old 11-27-2011, 04:34 PM
MTI
MTI's Avatar
Vehicle: '85 2.3-16 '99 C280 '11 GLK350
Bad aux water pump which is not sending coolant to the heater core, or a non functioning heater core valve which is not allowing the hot coolant into the heater core.
MTI is offline
post #3 of 4 (permalink) Old 11-27-2011, 04:47 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 68 Post(s)
I would say the latter is far more likely, aux pump failures are fairly rare, although certainly not unheard of.
flyboyike is offline
post #4 of 4 (permalink) Old 11-27-2011, 08:06 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 667 Post(s)
With a bad auxiliary pump, you should get some heat eventually, with a bad valve, you won't.
GeeS is offline
    1985 380SL Problem annagirl1966 R/C107 SL/SLC Class 11 03-18-2015 10:51 AM
    1985 380SL Major fuel Problem Billy Couch R/C107 SL/SLC Class 4 04-30-2008 11:44 AM
    1985 380SL shifting problem geoffmd General Mercedes-Benz 1 04-11-2006 07:46 AM
    1985 380SL Heater Problems Henry R/C107 SL/SLC Class 2 10-20-2003 01:32 AM
    1985 380SL Heater Problems Henry R/C107 SL/SLC Class 0 10-16-2003 08:31 PM
