changeing rear spheres - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 11-22-2011, 04:47 AM Thread Starter
Date registered: Nov 2011
the back end of my 1999 E300 td is bouncing up and down like a pogo stick so its time to replace the rear spheres looks like a fairly easy job but the oil and filter look very dirty so i will replace that as well i am thinking that if i run the engine when i have the pipes disconected it will pump out all the old oil and if i put a bit of fresh oil when the tank is almost empty in it will flush out all the old muck from the pipework can any one tell me if this will work or is it better to put the return pipe with the filter on it in to a bucket to empty the system before i disconect anything also when i fit the replacement spheres will i need to bleed them to remove any air that may have got in the pipes and fill the spheres with oil, any advise most welcome thanks ian
carrera32 is offline
post #2 of 2 (permalink) Old 11-22-2011, 06:23 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
See our W210 forum for advice.
flyboyike is offline
    changeing brake hose rear MadMax55 W123 E,CE,D,CD,TD,TE Class 1 09-30-2011 07:17 AM
    Need new rear-end spheres, cost for DIY vs. Ind'y 2005x W124 E,CE,D,TD Class 6 01-15-2010 01:35 PM
    DIY replacement of 560 rear spheres ? signut W126 S,SE,SEC,SEL,SD,SDL Class 14 11-06-2009 11:10 PM
    Rear spheres eprn1n2 W124 E,CE,D,TD Class 2 07-16-2007 12:35 PM
    I replaced my rear suspension accumulator spheres keystone76 W124 E,CE,D,TD Class 0 11-30-2006 12:09 PM
