06 c 230 recent transmission action - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 11-18-2011, 03:58 PM Thread Starter
Date registered: Nov 2011
Vehicle: 2006 Mercedes Benz C class sport cedan
i own a 06 c class sport. it has about 66000 on it. it started about end of last summer. when outside temperature dropped down a little. i noticed that it would shift with a little push at the slow down point from 2nd to the 1st gear. later, and a little colder, it started doing the same from 1st to 2nd also. that is when i find out that it doesn't do it when i warm it up little longer. back then it was like 4-5 min. so i started getting it warmer every morning. me and a friend desided to flash the transmission. he said it did help on one his benzes. so, magnits in the pen did not have anything on them. we put new fluid, gasket, filter, bolts. it did not change anything untill about two weeks ago. now, it never jumps or pushes from 2nd to 1st. but it got worst from 1st to 2nd. it seems like it is taking few more seconds to complete shifting. Notice, it does not doing that if i worm it up to 60-65 degrees. wich may take up to 20 min these days. when engene temperature is between 60 and 80 degrees everything is nice and smooth. any ideas? i thank you all
turnat is offline
post #2 of 2 (permalink) Old 11-19-2011, 03:42 AM
eric242340's Avatar
Quoted: 283 Post(s)
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see the Benzworld help section here:
BenzWorld Help - Benzworld.org - Mercedes-Benz Discussion Forum
Benzworld help is for general enquires and all technical questions should be posted on the specific forum for your car. If you are not sure which forum it should be on then please ask me and I will give you a link.
eric242340 is offline
    RW-1 in ACTION - (Scale Action) TRUKTOR Unimog 0 02-06-2011 04:01 PM
    Abrupt transmission shifts from 2nd to 3rd after a recent valve job JJB236 W124 E,CE,D,TD Class 0 02-13-2006 01:38 PM
    Rear blind action - as in no action lander91 W126 S,SE,SEC,SEL,SD,SDL Class 0 11-13-2005 04:31 AM
    Rear blind action - as in no action lander91 W126 S,SE,SEC,SEL,SD,SDL Class 0 11-13-2005 04:30 AM
    Recent service, transmission upgrade, front wheel damage..... Periokid R170 SLK-Class 6 08-13-2003 07:52 PM
