87 300E Starts then Dies - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 11-16-2011, 01:22 PM Thread Starter
Date registered: Nov 2011
Hello All
I am relativity new to the forum and have a problem with my 300E I wish to share..Perhaps someone else has had this issue and can steer me in the right direction..
My 87 300E has been sitting for quite some time..When I went to start it it kicked right over ran for 10-12 seconds the stops.. I suspected a fuel problem so I drained the fuel and put in fresh fuel..Same problem.. I pulled the air filter cover and put some clean fuel directly into the air intake of the fuel injectors..The car starts right up runs through the fuel then dies.. I can hear the fuel pump run for several seconds when I turn the key and it seems as though the car starts for a short time with the injected fuel from the pump.. I then jumped the fuel relay to get the pump to run continuously but the car still wont stay started..I also pulled the fuse for the OLP relay and still the car won't start.. Does this sound like perhaps a clogged fuel filter or what should I try next..Thanks for any advice and the welcome into this wonderful forum
Tony
87tbenz24 is offline
post #2 of 3 (permalink) Old 11-16-2011, 01:35 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
Proceed to the W124 forum and yes, a clogged filter would be a good suspect.
flyboyike is offline
post #3 of 3 (permalink) Old 11-16-2011, 03:05 PM Thread Starter
Thanks..Newbie
Tony
    1989 MB 300E starts when cold but dies when hot Riazcriaz General Mercedes-Benz 10 01-31-2012 04:07 PM
    87 300e starts hard & dies when throttle applied woody-500 W124 E,CE,D,TD Class 3 03-05-2010 01:57 PM
    Help! Starts normally then dies! Xmodius W126 S,SE,SEC,SEL,SD,SDL Class 21 08-14-2007 08:22 PM
    '88 300E will not idle - starts then dies, idles fine when ICV is unplugged- help! GermanCarNut W124 E,CE,D,TD Class 1 12-30-2006 10:08 PM
    280E Starts and Dies, starts and dies.... GermanCarNut W123 E,CE,D,CD,TD,TE Class 3 02-07-2004 07:28 PM
