hello to all, i have an issue that i would appreciate some help - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 11-16-2011, 09:40 AM Thread Starter
Date registered: Nov 2011
i have a 1999 500sl with the bose system, lately when i turn on the radio on cold mornings it sounds as though the speakers are blown, however once the car warms up the speakers and sound quality are perfect. i switched out the radio in dash and still have the problem, have checked out the speakers and they are fine. ive been told its the amp. i looked all over and the only thing that looks like the amp is behind the drivers seat. i was told it was in the trunk. cannot locate anything but cd changer....... any thoughts on location and if the amp is a common problem? thanks from a new member
jmor500sl is offline
post #2 of 2 (permalink) Old 11-16-2011, 05:20 PM
eric242340's Avatar
Quoted: 283 Post(s)
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see the Benzworld help section here:
BenzWorld Help - Benzworld.org - Mercedes-Benz Discussion Forum
Benzworld help is for general enquires and all technical questions should be posted on the specific forum for your car. If you are not sure which forum it should be on then please ask me and I will give you a link.
eric242340 is offline
    Strange Problem. A/C issue and engine cut off issue tied together 1989300se W126 S,SE,SEC,SEL,SD,SDL Class 1 04-03-2011 12:16 AM
    AC Issue & Tacho bounce - connected issue ?? scooters W203 C32 AMG, C55 AMG 1 04-24-2010 10:24 AM
    Airmatic issue, car sits uneven, ABS issue too. trader_reed W220 S-Class 1 01-25-2010 06:55 AM
    Radio Harness issue, Tuner issue DamianC R170 SLK-Class 1 08-28-2006 06:46 PM
    Brake-light issue leading to BAS/ESP issue??? Isoplus R170 SLK-Class 7 06-17-2006 12:57 PM
