too much oil - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 11-15-2011, 09:39 PM Thread Starter
Date registered: Nov 2011
too much oil
I have a 2001 c320...i got an oil change a few days ago and today "too much oil" light went on. I called the mechanic and he said that he put 9qt of oil even though the car takes 8.2-8.5 because the car has a slight leak. Can this damage the engine? Is it serious?
Also, my fuel gage doesn't read anymore. i think the censor is faulty. does anyone know how much it would cost to fix it? is it one or two censors?
yas21 is offline
post #2 of 5 (permalink) Old 11-15-2011, 11:10 PM
Kajtek1's Avatar
Quoted: 1223 Post(s)
Do you have a dipstick? How much above max it shows?
Kajtek1 is offline
post #3 of 5 (permalink) Old 11-16-2011, 12:47 AM Thread Starter
it doesnt have a dip stick. it reads it electronically when the engine is off. i just checked it and it says the level is ok... (doesnt say how much oil it has)
but the light is probably going to go off sometime when i drive the car tomorrow...
yas21 is offline
post #4 of 5 (permalink) Old 11-16-2011, 06:43 AM
Date registered: Nov 2003
Vehicle: 2004 CLK320
Quoted: 5 Post(s)
You can also get the exact amount of oil in the engine in dyno mode.
For my 2004 CLK320, these are the instructions to go to dyno mode:
1. Make sure the default mode in your cluster is set to temp.
(Close your door and windows supposedly)
2. Turn to ignition 1, within 2 seconds, press the dash reset handle 3 consecutive times till you hear a beep.
If you get into the dyno mode successfully, scroll till you see the oil level. Start the car and you will the oil level goes down as the oil get circulated to the engine.
Mine started at 7.9 - 9.0 L and and settled around 6.1-6.2 L while driving.
mis3 is offline
post #5 of 5 (permalink) Old 11-16-2011, 11:58 AM
Quoted: 5 Post(s)
As for too much oil, please refer to this link:
Can too much oil damage your engine ???? - Car Forums - Edmunds
mis3 is offline
