suspension problem: broken spring caps - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 11-15-2011, 07:39 PM Thread Starter
jessejames4's Avatar
Date registered: Jul 2006
Quoted: 2 Post(s)
I have a 1998 300E turbo diesel and the cap on top of the spring that holds the spring in place on the left front suspension has broken and bent back. Not much keeping the spring from popping out. A check on the opposite side shows that the cap is rusting there as well and it's just a matter of time.
I'm looking for an online electronic catalog to get the part numbers for these caps so that I can order them. Can anyone point me to a link?
Jesse
Fairfield county, Connecticut
86 Isuzu Trooper 2.23 TDi (the dog's)
12 VW Passat SEL Tdi (wife's)
07 E320 BlueTec (mine)
07 Sprinter CRD 2500 (also mine)
08 Arctic Cat ATV 700 Lombardi Diesel (mine all mine)
jessejames4 is offline
post #2 of 4 (permalink) Old 11-16-2011, 06:56 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
Try the W210 forum.
flyboyike is offline
post #3 of 4 (permalink) Old 11-16-2011, 09:40 AM
Date registered: Nov 2011
If you have a floor jack and jack stands it is pretty easy. You should probably change both springs.I would also get the sub-frame bushings, stabilizer links,engine mounts and shocks replaced.One of the most misunderstood components of the suspension system is the shock absorber - or damper, as it should rightly be known.
JohnMartyn is offline
post #4 of 4 (permalink) Old 11-16-2011, 09:24 PM Thread Starter
Quoted: 2 Post(s)
Thanks guys, I'm in the right area now.
Jesse
    Can you without problems change the V-class air suspension to spring suspension? kimberly V-Class 5 07-12-2010 04:30 PM
    Broken Spring E320Estate W210 E-Class 10 05-12-2010 05:24 PM
    Can you change the air suspension from a V-Class to Spring suspension? kimberly General Mercedes-Benz 2 11-16-2006 03:35 AM
    broken spring Kevin Van Caster W140 S-Class 7 07-15-2006 07:38 AM
    Broken spring Inblues W124 E,CE,D,TD Class 2 12-17-2003 02:08 PM
