Help! Engine in limp mode, 3 of 4 injectors not opening... - Page 2 - Mercedes-Benz Forum
post #11 of 16 (permalink) Old 11-18-2011, 09:33 AM Thread Starter
Date registered: Nov 2011
Vehicle: 1999 e320 RWD
Ok just updated my profile, thanks.
I'm in Alberta, Canada.
Interesting about the Magnaflow. I'm not sure if my cats to replace are rear or front.
I think I'll go with dealer for now (I want the car back asap and decrease chance of future problems/hassle), but next time the cat goes (hopefully in a long long time), I'll get aftermarket.
Funny that the left cat on my car was replaced in 2009. Now it's the right cat's turn. 280k kms on it.
hish123 is offline
post #12 of 16 (permalink) Old 11-18-2011, 09:37 AM
Kajtek1's Avatar
Quoted: 1250 Post(s)
Cats don't usually go bad on their own. I still would suspect you have/had fuel dump into the exhaust to cost that.
Do you do smog test in Alberta?
Kajtek1 is offline
post #13 of 16 (permalink) Old 11-18-2011, 09:54 AM Thread Starter
Alberta does not seem to have smog testing. But Ontario does. I might move to Ontario one day.
So you're saying there might be a problem behind the cats going bad, and it's not just wear and tear? I did ask the dealer about that btw, they didn't have an answer, except to say well my car is '20 years old' (it's 12 years old lol!), so it's just old stuff wearing out...
hish123 is offline
post #14 of 16 (permalink) Old 11-18-2011, 10:57 AM
Kajtek1's Avatar
cats usually burn out, not wear out.
So yes, IMHO they could be the result, not the initial problem.
You should find "carburetor shop" who could run the engine test for optimal performance, or you can start DIY by putting new plugs, MAF and O2 sensors.
Doing those things you will get your money back on fuel savings, so no reason to hold on them if they are due.
Kajtek1 is offline
post #15 of 16 (permalink) Old 11-19-2011, 09:09 PM Thread Starter
Ok thanks. I will check on that.
I did replace the spark plugs 4 months ago, the old ones were there beyond the time they were due I believe, so that may have contributed.
hish123 is offline
post #16 of 16 (permalink) Old 11-20-2011, 11:12 AM
Mar L. Barruel III, MBA's Avatar
Date registered: Feb 2008
Vehicle: 2005 ML500, 1999 C230 KOMPRESSOR, 1993 300E, 1964 220SE, 1994 E320, 2001 E320 4MATIC, 1991 380SEL
A clogged Catalytic Converter can cause a misfire!
I'M A FACTORY-TRAINED MERCEDES-BENZ MASTER SYSTEMS TECHNICIAN, ASE (AUTOMOTIVE SERVICE OF EXCELLENCE) MASTER AUTOMOBILE TECHNICIAN, BOSCH MASTER TECHNICIAN, MECP (MOBILE ELECTRONICS CERTIFIED PROFESSIONALS) MASTER TECHNICIAN, AND A L1 ASE & BOSCH ADVANCED ENGINE PERFORMANCE SPECIALIST WITH A MASTER'S IN BUSINESS ADMINISTRATION.
Mar L. Barruel III, MBA is offline
    ABS- ESP- Engine light- limp mode after car wash tbrown W211 E-Class 8 11-07-2013 09:36 AM
    Falling in Limp Mode Again With No Check Engine Light?? ZEvans W163 M-Class 18 07-30-2011 09:04 AM
    E320 Check Engine light-Limp Mode? Transmission? jchumba General Mercedes-Benz 5 11-01-2008 05:03 PM
    E320 Check Engine light-Limp Mode? Transmission? jchumba W210 E50 AMG, E55 AMG 3 10-25-2008 10:54 AM
    E320 Check Engine light-Limp Mode? jchumba General Mercedes-Benz 1 10-25-2008 08:30 AM
