HELP PLEASE craky winey noise - Page 2 - Mercedes-Benz Forum
post #11 of 28 (permalink) Old 11-11-2011, 08:02 AM
eric242340's Avatar
Quoted: 296 Post(s)
Originally Posted by mrgold View Post
ok checked both and the big one is full, but the little one was hard to tell because from one side it looked like it had like half but from the side that looks like sand paper on the stick thing it was dry i did it 3 times and same.
u think i have a leak ?
how can i fix this ?
thank you in advance for your guidance.
Pics would help at this stage so I can understand you better.
ERIC.
eric242340 is online now
post #12 of 28 (permalink) Old 11-11-2011, 08:14 AM Thread Starter
Date registered: Nov 2011
Vehicle: w215 CL500 2002., E320 1999 avantgarde(w210), 2011 E350 w212, Glk 2010
ok ill try to take some pics, i just never done it before.
what i was telling you is that the small oel (rubber) dipstick for the ps has 2 sides on one side says mercedes benz and on the other side is where the measuring lines are it has a rougher texture its not shiny, this side of the measuring oel stick was dry just the tip had fluid.
ill take the pics and try to post them asap
thanks again
mrgold is offline
post #13 of 28 (permalink) Old 11-11-2011, 08:18 AM
eric242340's Avatar
Quoted: 296 Post(s)
thanks again
Lets wait for the pics as this will help others who read this thread trying to fix a similar problem. And real time pics are not available in WIS, only in the classroom.
ERIC.
post #14 of 28 (permalink) Old 11-11-2011, 08:42 AM
eric242340's Avatar
Quoted: 296 Post(s)
thanks again
Got ya does this side of the dipstick look like XXX ? if so you need to add fluid.
ERIC.
post #15 of 28 (permalink) Old 11-11-2011, 11:08 AM Thread Starter
yes it does look like that, i just took it to benz and it was empty they filled it up for me for free, but the noise is still there much less though but it isn't gone completely and i can still feel a bit of friction in the steering wheel when turning to the right slowly or not moving.
does it take some time for the car to absorb the new(ps)fluid ?
thank you, i appreciate your help.
mrgold is offline
post #16 of 28 (permalink) Old 11-11-2011, 05:34 PM
eric242340's Avatar
Quoted: 296 Post(s)
Give it some time and pray. The duo pump for the ABC is an expensive unit.
ERIC.
post #17 of 28 (permalink) Old 11-11-2011, 05:38 PM Thread Starter
what is the The duo pump for the ABC ? i just replaced a pump the tandem is it related ?
thank you for your help again lol
mrgold is offline
post #18 of 28 (permalink) Old 11-11-2011, 05:51 PM
eric242340's Avatar
Quoted: 296 Post(s)
I believe we are discussing the same pump, it operates both steering and ABC and I would be straight back to them with this problem, I would also like to know where the steering fluid went.
ERIC.
post #19 of 28 (permalink) Old 11-11-2011, 06:17 PM Thread Starter
well i just bought the car like a week a go the seller changed the pump in may 2011 in mercedes benz of coral gables he gave me all the reports for the warranty purposes, i live in west palm beach do you think the warranty is valid in my local mercedes benz of palm beach ?
the fluid that they put today went in the ps reservoir (the small one located lower inside)( orangeish color), the abc reservoir was full (green color liquid)
i think i might have a problem with the ball joints too they a re squeeking scince today could that be ralted ? because other than that the car passed the 5 point satr benz inspection
i really appreciate your help thank you !
mrgold is offline
post #20 of 28 (permalink) Old 11-11-2011, 06:24 PM
eric242340's Avatar
Quoted: 296 Post(s)
You really must talk to your local dealer, at the very least have a chat with the service manager. I do not know what fluid they put in the ps but it should have been green too.
The Main ABC pipe has been modified as the old ones tend to burst, so I would ask the dealer to do a proper inspection of all the pipes/pump/steering and front suspension parts.
It is not uncommon for these pumps to fail in less than a year.
ERIC.
    W210 Road Noise & Active Noise Cancelation dragonflyer W210 E-Class 0 01-08-2010 05:34 PM
    W169 vibration noise when moving off and a seperate purring noise swiftguy W169 A-Class 1 10-13-2009 06:37 AM
    Rear end noise when break after starting/cold; wind noise from driver side window. zhuorongdeng W203 C-Class 1 07-03-2007 02:59 PM
    Lifter noise, miss, black smoke, and noise 1986 500sl Omani R/C107 SL/SLC Class 12 02-22-2005 04:13 AM
    "Squealing noise", and high pitched wind noise.... JKRD101 C215 CL-Class 0 01-01-2004 03:36 PM
