DRL question - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 11-08-2011, 10:09 AM Thread Starter
SHAUNE55's Avatar
Date registered: Aug 2010
Vehicle: 2001 E55 AMG
Quoted: 4 Post(s)
DRL question
I think you can turn on DRL in a W210 through the lighting menu when hooked up to the right diagnostics, that gives you front side lights only.
I was thinking more along the lines of LED's lower down like on newer cars.
In Europe all new cars have to have them and in the UK at least they come on when you start the car and by law have to either turn off when you turn on the lights or dim down.
There is a little module available that senses the lights coming on and turns of the DRL, or dims them depending on how it's wired.
Very easy to wire up but I was wondering if it would cause a bulb out warning when the lights are on.
Here's a wiring diagram of the module, a switch could be added to give a choice of off or dim.
I admit when I first heard of the new law (which doesn't require retrofitting to older cars) I wasn't too keen on the idea, but I've noticed that cars with them stand out during the day so hopefully reducing the risk of someone pulling out in front.
Eric Cantona quotes
When the seagulls follow the trawler, it is because they think sardines will be thrown into the sea.
SHAUNE55 is offline
    Question for anyone with C or E class 05-06 w/ Airmatic shocks. QUESTION PLEASE HELP! madmusic34 W211 E-Class 5 03-11-2010 12:33 AM
    1992 500e, Introduction, EGR Question & suspension question cars1050 W124 E,CE,D,TD Class 8 09-16-2009 07:14 PM
    lowering question and height adjustment question DnBtekhnic W203 C-Class 2 03-16-2009 08:45 AM
    instrument cluster question, A/C question, and hydraulic cylinder p/n question coolkid R129 SL-Class 3 06-22-2008 09:29 AM
    Shocks question/advice? RAYMOND, a question for you too! Cancer_Researcher W210 E-Class 10 03-11-2008 01:15 AM
