Help! 1986 Benz 300E stick shift idle problem - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 11-02-2011, 06:04 PM Thread Starter
Date registered: Nov 2011
I'm new to this so forgive me if I'm not posting in the right place or whatever.
I have a 1986 Mercedes Benz 300E 5 speed manual transmission.
As soon as I turn it on the idle goes up to like 5,000 rpm. I had a problem with the OVP (Over voltage Protection relay) before this happened. It would be hard to start when cold, but it would always start and the idle would be very low and the Antilock light would come on. I was told this was a problem with the OVP switch. After I would let it warm up the idle would just back to normal so I ignored it cause I live in San Francisco and only drive it once every couple weeks. Went to a party, drove fine there. I go out and started it and it just started accelerating. I kept it in neutral. I would give it gas and the idle would go down a little. It started to smoke near the back wheels under the car. Anyway, I replaced the OVP switch thinking that would solve the problem. It didn't. Only made it worse cause it fixed the low idle problem now the Antilock light doesn't come on and it just rev's even higher now. I'm not sure what's wrong. Could it be a stuck accelerator? A friend said it could be the clutch went out? Maybe the transmission went out? I have no idea. Please help if anyone has had this problem before.
Explosean is offline
post #2 of 2 (permalink) Old 11-05-2011, 06:44 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 67 Post(s)
Check your idle control valve, also proceed to the W124 forum.
flyboyike is offline
    300E 5spd stick shift german junky For Sale/Wanted/Trade/Giveaway 1 02-12-2011 05:15 PM
    1985 Mercedes Benz 190E 2.3 Stick Shift (5 Speed Manual Transmission) in Rockville, M romanysoe For Sale/Wanted/Trade/Giveaway 4 05-08-2009 07:06 PM
    WTB: 300E Stick Shift wdba123190 W124 E,CE,D,TD Class 0 04-21-2004 02:14 PM
    Please help, advice needed on Stick shift problem ? (longish) Stretch R170 SLK-Class 19 04-15-2002 05:28 AM
    how is a 300E with a stick?if bad how to fix shift Guest (MBNZ) W124 E,CE,D,TD Class 4 10-30-2000 04:43 AM
