New member in need of some help! - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 11-02-2011, 03:19 PM Thread Starter
Date registered: Nov 2011
Vehicle: 2010 Sharan, 2001 Golf, 1989 560SEL, VFR800, CBR400 (!)
Evening all,
I'm new here and in need of some help. I've just taken ownership of an 89 560SEL - beautiful car!
I only plan on getting the car MOT'd and then getting shot of it but therein lies the problem!
I've had a mechanic look it over and all looks sound apart from two main things - the vehicle idliing at 1600RPM which (after some extensive reading) I'm maybe thinking the ICV and secondly the suspension isn't rising.
Soooo. I'm reasonably handy with some tools and a multimeter and would like some assistance in diagnosing the suspension. From what I've read up on, it's SLS with the pull knob next to the lights.
Can someone point me in the direction of a good technical description of how to troubleshoot the suspesion and how it works? And also where I should start with diagnosing the fast idle?
Just looking to get the car MOTd and get shot of it so I would appreciate it if someone could give me an idea of it's worth.
There's no service history, last MOTd four years ago and from what I remember, 110K on the clock. Bodywork in good condition apart from some rust on the offside front wing. 18" AMG wheels and all electrics working.
Thanks for the help in advance. It'd be good to talk to someone technical about the car so if you have some time and would like to help a novice (!), send me a PM please and I can give you a shout.
Cheers all,
calumski is offline
post #2 of 6 (permalink) Old 11-02-2011, 04:13 PM
RedLiner's Avatar
Date registered: Sep 2006
Vehicle: 1998 Pano SL500; 1993 SL500; 2005 ML270cdi
Quoted: 356 Post(s)
Hello and welcome, if you look on the main board index for your model 89 560SEL, you'll get a far better response
No trees were harmed creating this message, however some electrons were very inconvenienced.
RedLiner is online now
post #3 of 6 (permalink) Old 11-02-2011, 04:17 PM
Mercedes mechanic's Avatar
Date registered: Mar 2011
Vehicle: Timeship, see you yesterday, but you already knew that.
Before you tear into anything have a smoke test done.
As far as the suspension problem, have you checked the fluid level?
Mercedes mechanic is offline
post #4 of 6 (permalink) Old 11-02-2011, 04:21 PM Thread Starter
Cheers guys. RedLiner I will do. Thanks.
I would check the fluid levels if I knew where to find the reservoir! Where abouts is it housed?
Why a smoke test dare I ask? Is there a good chance that the bores/rings would be worn? It's not really been run on a log journey in four years when it last passed it's MOT.
calumski is offline
post #5 of 6 (permalink) Old 11-02-2011, 04:36 PM
Sith Lord
elbeik's Avatar
Date registered: Sep 2009
Vehicle: 72 280SE 88 560SEC 92 E500 6.0 95 SL320 14 GLK350
Quoted: 212 Post(s)
Welcome aboard; you should chime in into the w126 section for abundant resources relating to your car.
High idle is mostly related to your Idle Control Valve as you mentioned.
Clean it first, and see how it goes before replacing it.
The SLS system has a pump + "balls" in the back - that can fail.
elbeik is offline
post #6 of 6 (permalink) Old 11-03-2011, 01:58 AM
eric242340's Avatar
Quoted: 283 Post(s)
The "balls" of which you speak are called accumulators and they are there to keep the pressure balanced, they have a diaphram inside that fails.
Balls by gad, laughing stock more like. You can feel the farce in them.
eric242340 is offline
    new member alfalfa General Mercedes-Benz 1 08-01-2010 10:34 PM
    New Member Looking_In_MD General Mercedes-Benz 0 03-03-2009 04:01 AM
    Hottest SLK from a member or X-member of this forum... post them up. OJwerks R170 SLK-Class 21 01-28-2009 10:13 PM
    wtf, i'm a "member" here but i'm a "senior member" at MBWorld!! asianml Off-Topic 8 11-23-2005 05:19 PM
