722.6 transmission filter - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 10-31-2011, 07:10 PM Thread Starter
Elvis_Presley's Avatar
Date registered: Apr 2011
Vehicle: 2002 e320 4matic Wagon
Quoted: 40 Post(s)
The filter i jist installed didn't snap in and i am worried about it. Anyone know which way the fluid runs through the filter? If it runs from the bottom through the top, it would tend not to force the filter off. But if it runs that way, if the filter did come off, it would be dangerous if the fluid was low.
Elvis_Presley is offline
post #2 of 7 (permalink) Old 11-01-2011, 08:29 AM
Musikmann's Avatar
Quoted: 6 Post(s)
I remember reading that those don't just snap in. Somehow you need to "wedge" it in when putting the drain pan back on. The description sounded a bit tricky to me. I don't know about the fluid path.
Musikmann is offline
post #3 of 7 (permalink) Old 11-01-2011, 06:46 PM
PLeeson's Avatar
Date registered: Apr 2007
Quoted: 5 Post(s)
If the old rubber washer is still up in the housing, this might cause this sensation.
With a little ATF on the new one, a little wiggling and pushing is needed to seat it.
The fluid is sucked up from the bottom of the pan.
Phil
Prior MBs:
1971 250, 1983 380SEL
1986 190E2.3, 1987 300TD
1994, 2003, 2005 SL500s
2001 E320 4Matic
2011, 2012 E350 4Matics
2012 S550 4Matic
PLeeson is offline
post #4 of 7 (permalink) Old 11-01-2011, 07:13 PM
Mercedes mechanic's Avatar
Date registered: Mar 2011
Vehicle: Timeship, see you yesterday, but you already knew that.
Originally Posted by PLeeson View Post
If the old rubber washer is still up in the housing, this might cause this sensation. With a little ATF on the new one, a little wiggling and pushing is needed to seat it. The fluid is sucked up from the bottom of the pan.
Great advice.
Also it does clip in. View circled area. This snaps into the valve body in the back.
All you will see is a small slit machined into the body. To help you in finding the slit, put main pick-up tube into general mounting area.
Mercedes mechanic is offline
post #5 of 7 (permalink) Old 11-01-2011, 09:16 PM Thread Starter
Quoted: 40 Post(s)
The one i bought--a mann "made in china" didn't have the clip, just a tab in the same location. The one that came out of the car--which may be the original, didn't have the clip either--but appeared to be much better quality.
i think after a lot of wiggling that i got it to seat. But is there a chance it could fall out, or will it hit the bottom of the pan before it as able come out of the housing.
post #6 of 7 (permalink) Old 11-01-2011, 09:19 PM
It sit's off of the pan floor by 1/4 inch. No its not going to come out.
post #7 of 7 (permalink) Old 11-01-2011, 09:42 PM Thread Starter
Quoted: 40 Post(s)
thanks mechanic dude!
    123? Transmission Filter Kit skullandbones For Sale/Wanted/Trade/Giveaway 0 10-13-2011 12:10 PM
    Transmission Filter/ Filter Kit Tomten W123 E,CE,D,CD,TD,TE Class 2 01-07-2011 01:08 PM
    722.3 transmission oil and filter philip29 W140 S-Class 4 05-28-2010 06:26 PM
    transmission filter dusty88 W124 E,CE,D,TD Class 1 03-03-2010 07:22 PM
    transmission filter kit daryn R/C107 SL/SLC Class 2 09-15-2008 11:42 AM
