Belt tension bar and assembly - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 10-30-2011, 12:56 PM Thread Starter
Date registered: May 2011
Im having a problem keeping a new belt tight. I replaced one of the belts after replacing the fan clutch yesterday and today the belt was loose and making noises. I know I tightened it correctly yesterday so I may have a tension bar problem. My question is, are there any troubleshooting tips out there and if it is a tension bar problem do I have to replace the entire assembly or can I just replace the tensioning bar? My MB is a 1991 300TE. The is a salvage yard near by with a few newer models that still have some engine parts available in case there is a part I can use from them. They look to be in the mid 90's and they are sedans like the 420sl or maybe a 300??
Thanks and hope to hear some good news!
Ed
emendoz1 is offline
Serpentine belt tension pdf? augapfel W124 E,CE,D,TD Class 15 01-16-2012 12:03 PM
Serpentine belt tension gtone W201 190-Class 6 10-04-2009 08:08 AM
adjusting belt tension einspritzung W124 E,CE,D,TD Class 6 09-27-2008 09:30 AM
Serpentine belt tension? White_Knuckles W124 E,CE,D,TD Class 3 08-19-2007 11:01 PM
checking belt tension andrew_falky W126 S,SE,SEC,SEL,SD,SDL Class 2 06-09-2006 10:27 PM
