2006 SL 55 AMG Problem - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 10-30-2011, 06:48 AM Thread Starter
Date registered: Dec 2008
My customer has a 2006 SL55 AMG and his panel says intorior accessories not avalible.
His steering wheel wont adjust and his seat wont adjust. He tried replacing the fuse because it burnt out and it worked agian for awhil longer then stopped working agian and this time the fuse is ok.
What might cause this?
I will be checking car out for the next two days to see what electrical is causing it, have not had a chance to get to this car yet. Just curius if there is a TSB or maybe this was a common problem, or someone else here had the same problem.
jay173 is offline
post #2 of 5 (permalink) Old 10-30-2011, 07:00 AM
television's Avatar
Date registered: Sep 2005
Vehicle: 216 with everything. 2002 SL500 with everything. 2009 SL500 with everything.
Quoted: 148 Post(s)
This is normally the rear battery to low in voltage,, if this battery drops below 11.75 volts the consumers will be turned off
Malcolm
"I thought my vasectomy would keep my wife from getting pregnant but apparently it just changes the color of the baby."
television is offline
post #3 of 5 (permalink) Old 10-30-2011, 06:25 PM
Date registered: Apr 2009
Vehicle: 1999 E300TD
television's post is correct. It shuts off consumers so it doesn't waste power. Once the battery has charged up again the consumers will come back on once there is sufficient voltage.
saleen1276 is offline
post #4 of 5 (permalink) Old 10-30-2011, 06:30 PM Thread Starter
So how do I gain access this rear battery?
jay173 is offline
post #5 of 5 (permalink) Old 11-05-2011, 08:13 AM
Date registered: Nov 2011
Question 2006 sl 55 rear battery low
I have the same problem, you can access the rear by taking the long narrow silver part of your key off and sticking it in the lock ,its under there by the license plate light or something, it turns like a regular car lock. the battery is under a thin wood cover. My question is it costs $150.00 for replacement with vent tube . from interstate batteries. recommended replacement. However a sealed battery is better ,I think, ....costs a little more but no tube................. is this o.k. to replace this way
bryanhark is offline
    2006 CLK 350...Problem ? ? ? donald1111 C209/A209 CLK-Class 66 06-14-2016 06:56 PM
    Problem with ASC on 2006 Sprinter BillTomko W901-905 Sprinter 1 11-10-2009 10:05 AM
    I have Problem in my G55 – 2006 model alkandt G-Class 0 08-06-2009 07:11 PM
    2006 CDI Shifting problem Miami320CDI W211 E-Class 4 02-07-2006 11:26 AM
    Any Problem with your New 2006 ML jean7of9 W164 M-Class 2 05-05-2005 01:02 AM
