New member with a shock question - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 10-28-2011, 11:51 AM Thread Starter
Date registered: Oct 2011
Recently purchased a 2007 gl320 with 77K miles. Had sedans in the past. In going over the car I noticed I have leaking rear shock, no big deal,a little expensive. Where or how do you get to the top rear shock bolt. Thought it might be in the wheel liner no, under the seat?, behind the interior panel???? Looked straight forward from underneath. Any help would be appreciated.
malencer is offline
post #2 of 2 (permalink) Old 10-29-2011, 05:45 AM
eric242340's Avatar
Quoted: 295 Post(s)
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see the Benzworld help section here:
BenzWorld Help - Benzworld.org - Mercedes-Benz Discussion Forum
Benzworld help is for general enquires and all technical questions should be posted on the specific forum for your car. If you are not sure which forum it should be on then please ask me and I will give you a link.
Regards
ERIC.
eric242340 is offline
    Air shock question nspeed X164 GL-Class 0 12-12-2010 01:22 PM
    ---Rear Shock question--- Surakung W210 E-Class 6 11-14-2010 10:56 AM
    Question about shock replacement. starcar126 W126 S,SE,SEC,SEL,SD,SDL Class 4 05-11-2006 06:52 AM
    Last question before shock change Tbilisi79 W140 S-Class 4 12-07-2005 06:55 AM
    spring/shock question belosch G-Class 29 09-12-2005 02:47 PM
