replacing sun roof bead - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 10-25-2011, 11:21 PM Thread Starter
Date registered: Nov 2010
Vehicle: 1995 SL 320, 2008 CLK 350
this is on a 2008 clk 350, but I think applies to many other models too.
the bead is "fuzzy" material covered with a vinyl sheath, and the vinyl is disintegrating with little pieces coming off. No leaks, just a cosmetic thing. Dealer will replace as car is under warranty. but I am dubious about having the work done if it involves taking much of the roof apart.
maybe the fix will be worse than what I have now?
maybe I should well enough alone? how much trouble is it to replace the bead ?
M-B advisor says if it was his car he would leave it alone, but since it is covered by warranty, etc.,etc..............mumble, mumble.
any advise out there ???
jack ullrich is offline
post #2 of 2 (permalink) Old 10-27-2011, 06:53 AM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T current 2014 lexus LS460
I did it after the body shop screwed it up repairing some minor rust. The seal is a few hundred and should be installed by working it all the way around.There is a front and rear also a up and down. I started in the corners and worked back and forth using a wallpaper seam roller to seat it fully. the body shop idiots stuffed it in an then cut it when it turned out to large. I made them buy another and I installed it
Peter Guenther is offline
    Replacing Entire Roof Aerial/ Antenna feje133 W203 C-Class 1 12-23-2010 02:04 PM
    Is the bead off on these tires??? reyna7 The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 05-29-2008 08:17 AM
    Replacing interior Roof Cover gsj224 W163 M-Class 0 12-28-2006 06:57 AM
    squeaky roof after replacing roof liner gpreyes R170 SLK-Class 1 08-02-2006 10:21 AM
    REPLACING SUN ROOF MOTOR BIZYGUY W140 S-Class 1 08-02-2004 05:31 PM
