C180 AUTO Nreg cutting out - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 10-24-2011, 04:50 AM Thread Starter
Date registered: Jun 2011
Question C180 AUTO Nreg cutting out
hey. my mums c180 AUTO is a right sod this year. got only 64k on the clock and for the past month it has been fine, BEFORE; it would cut out usually when you had the radio on and were at low speeds, usually coming to a stop. no warning, always started up again just very random engine stopping. took it to merc a few times and they said no faults at all they just reset something as you do after a head gasket job apparently. i have done the head gasket, then changed heads etc totally cos the cam decided to snap in half on the road test, then we have done a couple of little things to the gearbox as the vac pipe come off and the prop coupling was shot away. and replaced the battery. AND i redid some of the engine wiring loom as this car obviously still came with the crap wiring loom that falls apart after a few years. AGAIN, we have had merc and the AA and an auto electrics place look for a bloody fault and there is absolutely nothing to report.
thought we cured it with the amount we did. NOW, after a month, it happened again today as my mum was going along without the radio on.
the only thing i will say is the car will not start after removing the battery cos i was sat there for DAYS trying to start the bloody car after changing the battery on a few occasions! it was having none of it. but out of the blue after a few days of struggling to start (and i even tried my new 700 amp v12's battery and got the same shitty response from the car) it was fine, and is still fine starting up. but again if i pulled out the battery it will really go bad again.
i dunno what the hell is going on. ive spent nearly a thousand pounds on this low milage poxy car and thats with me buying cheap and doing it myself! it just stops. for no reason. no warning light no noises no nothing. ecu doesnt even have a record. (oh and no i dont have a cruise control!)
any ideas?
LUCIFER-V12 is offline
    '97 c180 cutting out.. LUCIFER-V12 W220 S-Class 5 10-25-2011 01:06 PM
    c180 petrol auto 2002 help colinmacdonald General Mercedes-Benz 3 07-19-2011 02:49 PM
    V220 CDI Auto cutting out??? Djin0 V-Class 14 12-22-2010 11:46 AM
    1998 C180 starting then cutting-out Minimart1701 W202 C-Class 0 10-05-2009 11:48 AM
    c180 auto revving problem SirBobbington W202 C-Class 0 06-21-2007 05:15 AM
