2003 ML350 gas cover won't open. - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 10-23-2011, 11:08 AM Thread Starter
Date registered: Jul 2011
I stopped to get gas and I couldn't get it open. Not the cap, the door that you have to open. How do I manually open it?
Jeremy0734 is offline
post #2 of 4 (permalink) Old 10-23-2011, 01:03 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 67 Post(s)
Take a flathead screwdriver and wrap it in Scotch(R) tape. Slowly and carefully pry the door open with thus-modified screwdriver.
flyboyike is offline
post #3 of 4 (permalink) Old 10-23-2011, 01:14 PM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 343 Post(s)
Not sure about your ML 350 - but I'll bet it is the same as my CLK.
You open the trunk, and remove the trim on the side where the filler cap is located. Now you can reach inside and turn a lever that manually opens the fuel flap.
keyhole is online now
post #4 of 4 (permalink) Old 10-24-2011, 01:58 AM
Date registered: Apr 2006
Do not prize it open! On the ML unlike many other Mercedes the flap does not open in the conventional way. On most you press one end and the other end comes out (like a see saw). On the ML you press one end and that end pops out. You push to open and push same place to shut. Confused me for a while having had an E class before the ML.
Or you have a fault and it has jammed. In which case ignore this posting and follow the others.
This may amuse: -
Understeer is when you hit the wall with the front of the car, oversteer is when you hit the wall with the rear of the car.
Horsepower is how fast you hit the wall and torque is how far you take the wall with you.
ML350cdi Sport
E220cdi Estate Avantgarde (sold)
S class 320 cdi 2005 (sold)
hawk20 is offline
    Doors wont open 2006 ML350 stanza2001@yahoo.com W164 M-Class 13 10-27-2011 09:49 AM
    Doors wont open 2006 ML350 stanza2001@yahoo.com General Mercedes-Benz 1 09-06-2011 05:06 AM
    2003 ml350 rear tow hook cover arjun_dw W163 M-Class 0 07-05-2010 11:04 PM
    cover compartment open and roof will not open soca rebel C208/A208 CLK-Class 3 03-10-2009 07:51 AM
    Help! I cannot open my gas cover. USA Soccer W201 190-Class 3 01-08-2008 09:45 AM
