05 Sprinter shifter troubles. - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 10-22-2011, 05:12 AM Thread Starter
Date registered: Oct 2011
Vehicle: 2005 Dodge Sprinter 2500, 158" wheel base High top.
Send a message via Skype™ to jcweller1
Exclamation 05 Sprinter shifter troubles.
HI all. I posted the other day about issues with my sprinter related to an overheat etc. I get it back from the shop and it wouldn't start unless I wiggled the shifter. This was in intermittent problem until last weekend. Since then I have replaced the shifter with a new Mercedes unit from the local Dodge dealer. I was told by the parts department that Mercedes has had massive issues with this style of shifter and that the dealership had to replace the shifter in their Sprinter as well.
A year ago I replaced the brake switch as I was getting ABS lights and all the other lights that the switch controls. At that time I also couldn't shift the van into gear without tripping the park lock. Replacing the switch worked well and I have had no problems until this shifter issue. Most of the time I turn the key and the engine won't turn over. Sometimes if I try it a few time it works. Other times I have to wiggle the shifter in the park position or even trip the park lock to allow me to shift to neutral to try to start it.
After replacing the shifter assembly, all worked fine for 2 days. Now I'm back to the same issues and not knowing when I will have troubles starting the van. I have made sure the trans shift linkage is adjusted properly. I have taken all the wiring connectors and cleaned them with contact cleaner to be sure there isn't a corrosion issue.
Another foreign car tech told me yesterday that the new shifter could be the issue as he has seen them faulty right out of the box.
If any one has any ideas I sure could use the guidance.
Thanks in advance,
jcweller1 is offline
post #2 of 3 (permalink) Old 10-22-2011, 06:09 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 67 Post(s)
If you don't mind clarifying, it starts every time in neutral, but not in park, correct? Also, when it's not starting in park, you have difficulty getting it into neutral at the same time or are those separate problems?
flyboyike is offline
post #3 of 3 (permalink) Old 10-22-2011, 06:29 PM Thread Starter
It will sometimes start in park if I wiggle the shifter. When it doesn't start in park I have to trip the park lock and shift into neutral, but that doesn't always mean it will start. Sometimes I have to play with the shifter in park and neutral.
This morning it started fine in park. After reading some other posts I decided to re-adjust the trans shift cable. I shortened it by about 1/8th of an inch and it has worked fine all day. Now this evening I started it and took off and all the ABS, ESP and Brake warning lights came on. The brake lights work. I shut it down and restarted and drove off with no more lights? HMMMM The trans shifter cable adjustment fixed the starting problem. At least for the present. I shall see what happens with a few days of driving.
    New Guy With 05' Sprinter Shifter Troubles jcweller1 General Mercedes-Benz 1 10-18-2011 07:49 AM
    A/C troubles 79Mercy W123 E,CE,D,CD,TD,TE Class 0 06-25-2007 09:25 PM
    OIL troubles...what should I do ? mbeclass W124 E,CE,D,TD Class 5 07-23-2006 08:08 PM
    Ultimate Windsurfing Van - Freightliner Sprinter Van Dodge Sprinter Saigon76nyc W901-905 Sprinter 3 10-06-2005 11:17 AM
    Help! Having car troubles... Patrick R170 SLK-Class 8 02-18-2002 08:51 AM
